Question about Whirlpool Cabrio Washing Machines
Wtw5640xw2 Only Filling and draining of machine works
Problem started with loud knocking sound during spin start up after machine spun up the sound went away next a loud noise started when agitating cycle is running. Sounds like something was slipping or a metal on metal sound. This happened for two washes loads. Now it appears that only the filling and draining of the drum works. Model number WTW5640XW2 Serial Number C12831641
  • 249 Answers
SOURCE: Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Posted on Dec 17, 2007
SOURCE: loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
  • 7 Answers
SOURCE: Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Posted on May 05, 2009
BIKER T
  • 909 Answers
SOURCE: wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Posted on Sep 20, 2009
  • 382 Answers
SOURCE: Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Posted on Jan 07, 2010
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Air power bubble washing machine model -dwf -1150p
Daewoo Airpower Bubble Wash Machine Model - DWP - 1150P
My Machine does not want to spin anymore. It makes a knocking sound and then stops and starts filling up with water again, then drains it and wants to start spining and again makes a loud knocking sound and the repaets the already mentiond sycle. Can you help me with this problem? Does Daewoo not have service centers for these machines?
Apr 21, 2013 | Washing Machines
2002 Mazda Protege 5 knocking engine
Uhh there are no rods in the head. That dealer has a loose rod in his head maybe.
The crank, rods and pistons are all in the bottom end of the engine.
What it likely is is either a broken piston skirt or a spun rod bearing.
Spun crank bearings are rare and sound deep.
A spun rod bearing can be fairly quiet on idle depending how bad it is worn out, but it will be really loud on acceleration. Piston slap from a broken skirt can be pretty loud too but it mostly sounds like diesel rattle only a bit less. Some have described it as a loud pinging sound like detonation.
Drain the oil and check for metal debri. If you can tilt the vehicle a bit for the oil to drain more towards the drain hole that could help. Then look for metal pieces and judge their size. There should be NO glitter whatsoever in engine oil, or any kind of debri. Now a rear end or transmission is different. Those always have a little metalic sheen to them.
Best of luck.
Apr 01, 2010 | 1986 Mazda 626 Coupe
Kenmore HE3 washer makes a dull click noise during spin cycle. I opened the back cover and tried to spin the pulley. As I spun the pulley, I can hear a dull thud noise as I spun. Is there a bearing or...
This is caused by air getting in the pump (from too many suds). So the pump can't pull a good stream of water ( it cavitates like a boat prop). Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Mar 18, 2009 | Washing Machines
Washer won't spin and keeps filling
one thing is wrong is balance.That's why it knock the wall down.Don't know to much about GE.But I would check the dasher to see if it's down.But the belt could be broken under the washer.
Mar 13, 2009 | GE WSKS2060WWH Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
