Question about NEC Lands Phones
Nec XN120 issues with calling just one extension goes to load speaker
Nec XN120 calling one extension phone automatically answers with loudspeaker when doing an internal call any reason for this? only resonantly happened and no changes have been made to the PBX though not sure if the user has made changes through the handset
  • 43 Answers
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Posted on Feb 12, 2008
  • 43 Answers
SOURCE: NEC DTERM 80 Call to speakerphone
While the station is ringing - Press "1"
The feature must be enable in programming to be active.
Posted on May 10, 2008
SOURCE: TalkSwitch 48 disconnects call after transfer
You are using the wrong option for transfer -- the one you are using is a conference which requires the person transferring the call to stay on the line. You need the option which permits a blind transfer or announced transfer. This issue is specifically discussed in the manual.
Posted on Mar 08, 2009
consultel1
  • 860 Answers
SOURCE: My message button automatically calls another
the reason the message button is calling another extension is because that extension turned your message light on. to turn off the message light either press the msg button and have the extension answer the call or press intercom #409. You'll have to that for each message recieved til the light goes out.
Posted on Oct 13, 2009
ThePoodleGuy
  • 24 Answers
SOURCE: I have a Panasonic KX-TGA652 dual handset no
Id try the following in this order:
  1. Try swapping batteries with another set and see if the problem follows the battery
  2. Try re-registering the handset, they could of missed one at the factory. that is done by selecting menu->initial settings->register handset
If this doesn't work, then return for warranty/exchange. Mine seem to work great right out of the box.
the poodle guy!
Posted on Nov 21, 2010
How do I set up call forwarding on a NEC dterm series i
On an Elite it's SPEAKER 43 + the extension you are forwarding to. These phones work on about 6 different NEC systems, so this may not work for you. Oh, cancel for this code is SPEAKER 44.
Dec 22, 2014 | NEC Lands Phones
How to divert calls
You can forward all to another extension or to an outside number. You can also forward busy/no answer to both of those, but then it'll cancel your busy/no answer to voicemail. Speaker 41 plus ext or 9 plus outside number will set CF ALL, speaker 43 will set CFBNA, 42 and 44 to cancel. These are the default codes for NEC pro II, Elite, and IPK. The DTP phone also works on other systems that have different codes.
Jul 23, 2014 | NEC Dterm DTP 16D-1 Corded Phone
When I make/receive a call, the phone is automatically on (loud) speaker.
http://www.applevis.com/forum/ios-ios-app-discussion/every-time-i-make-or-receive-phone-call-automatically-goes-loudspeaker
Mar 10, 2014 | Samsung Galaxy Pocket
When i transfer to another extension, the call is automatic in speaker phone, why?
The handset has been programmed to auto answer all or some calls. You will need to change it to normal answer mode via EXTN 20/21 whichever is your programming extension. To tell which one is your default extension it is usually the extension that will still work as a normal telephone in the event of a mains power failure.
Aug 26, 2013 | Panasonic KX-T7730 Corded Phone
How do you take out voicemail from the phone so call forwarding can be processed?
I'm not sure that you are phrasing the question correctly. How can I bypass the voice mail box would be a better explanation.
If you take out the voice mail box it will go to the main greeting. Call forwarding to voice mail is call forwarding being processed. Is there somewhere else you would like it to forward to?
If you are just trying to delete your mailbox then you need to know your system manager info. If you do email me at IsaiahJ1980@gmail.com and I can help you further.
Call Forwarding Options:
From Port 1
Find port 01 or Tel 01 by pressing feature 4 from the lowest extension # in your system. Once you have found port 01 dial either of the following:
Call Forward Busy No Answer
Speaker 45, enter the extension you want to forward i.e 103, enter the destination, another extension perhaps 107 and speaker.
Call Forward Busy No Answer to an outside #
Speaker 45, enter the extension you want to forward i.e 103, press 9 and enter the destination phone # and speaker.
To Cancel Call Forward BNA
From port 1: Speaker 46 and the extension #
Call Forward All
Speaker 47, 103, enter the destination extension 107 and speaker.
(You will notice the Feature light flashing after this operation)
Call Forward All to an outside line
Speaker 47, 103, 9, enter the destination phone # and speaker.
To Cancel Call Forward All
From port 1: Speaker 48 and the extension #
Nov 13, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Line rings does not fo to voice mail
The call forwarding was canceled; try this
1. pick up handset or press speaker
2. dial the code for call fwd busy/ no answer (default code is 744)
or press the forward function key
3. dial 1
4. dial the extension (lead number of your voice mail)
5. press speaker or hang up
May 20, 2009 | NEC Lands Phones
Change clock time.
The XN120 I know is a PBX, so setting the time sets it for all phones connected to the PBX. The time can only be set on an XN120 system phone which has an LCD display (or a PC - see below). It's quite complicated - refer to setup guide such as
http://www10.GIScafe.com/nl/newsletter_confirm.php?enc_email=ZGF2ZS5jb3ZlbGxAc2lnbWFzZXZlbi5jby51aw==&subscriber_key=5d4ff921b647525ca172f7fb11ae56b4
Some of these PBX systems have TCP/IP network cards installed so the time can be set from the NEC PC-Pro configuration program run on a network connected PC.
Nov 10, 2008 | Lands Phones
Speaker picks up automatically
callers maybe calling you and than pressing 1 to voice call you. Dialing your extensions than 1.
Pick up the handset before pressing speaker.
Mar 12, 2008 | NEC Electra Elite 32D-1 Corded Phone
Voice vs ring on intercom
Speaker - "60" - Speaker.
This is the default setting for Voice / Tone toggle.
Feb 26, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
82 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
