Question about John Deere Garden
John Deere 855 Compact tractor has no power to solenoid
Can jump across solenoid and tractor will start
  • 430 Answers
Power from the battery direct to a big terminal on the solonoid. The other big terminal leaves the solonoid for the starter. Then there are either one (1) or two (2) smaller terminals on the solonoid. If there is one then the body of the solonoid is the ground. With two of course the extra is the ground. Make sure the solonoid has a good ground.
Remove the smaller terminal from the solonoid ( usually yellow) and connect the positive end of a multimeter or a DC volts tester to it. ground the other end of the tester and turn the ignition key to start. If you get 12 volts to the wire end then the solonoid is bad and should be replaced. If no voltage is registered then the ignition switch is bad or an inline safety switch such as: nuetral, clutch/brake, PTO, seat ( Operator Presence Switch). Or you have a bad wire, bad ground, bad connection somewhere in the starting system.
Posted on Nov 01, 2012
4 Suggested Answers
  • 246 Answers
SOURCE: Left side headlights and tail have no power coming
Hello feeze1:
>>Using a Continuity Tester (Multimeter) and Check the Wires.
>>From your Description it Sounds like there is a Broken Wire in the Harness.
>>Usually I Route a New Wire or Wires to the Effected Light Assemblies if a Wire in the Harness is the Cause of this Problem.
>>On Most Units it is a Hassle to Repair a Wire or Locate the Exact Break in a Wire in the Harness.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
JOHN DEERE COMPACT TRACTOR 4710 RECEIVS NO POWER TO FUEL SHUTOFF SELENOID OR INJECTION PUMP BUT WORKS IF JUMPED FROM STARTER DIRCTLY
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Sep 09, 2016 | John Deere Garden
John deere x540 with140 hours. Jump started from storage and cut 2 hours without issue. would not crank back up. Installed new battery and checked fuses. Lights and all come on but will not crank.
would not crank Chet, Relay,Solenoid or starter may be defective, give the starter a sharp bang with a hammer, to see if it is stuck.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Test lawn Mower Solenoids
How To Test Solenoid with Taryl
Electrical System Troubleshooting for Lawn Tractors Mowers
JOHN DEERE KAWASAKI RELAY
Mar 30, 2016 | John Deere Garden
Have replaced the solenoid and the seat saftey switch. Mower will only start if I jump the solenoid.
Is it a 3 or 4 post solenoid. Three post need scrap the frame wear the bolts go for good ground.
May 14, 2015 | John Deere 108 111 116 & H L&g Tractor...
How do i jump start tractor by solenoid?
If your battery has enough power to start the engine but the solenoid is bad, just touch the two large posts on the solenoid at the same time with a piece of metal like an old screwdriver.
Oct 13, 2014 | John Deere 3010,3020 Tractor Basic...
John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Mar 28, 2012 | John Deere Garden
Model 870 will not start. A new battery has been installed and there is power to the lights but noting appears to get to the starter .
Check your starter solenoid. Find it by following the pos. battery cable back to it, using jumper cable jump acrossed to other big cable on the other side of solenoid. With key in on position it should run. If it does eigther solenoid is bad, or ign swithc or the connections are dirty.
Oct 02, 2010 | John Deere &Reg Branded 27" Tractor Metal...
John deere 425 lawn tractor. it wont start but it has spark and fuel the starter engages and the fly wheel turns
If your tractor has an anti back fire solenoid in the front of the carburetor then it should start if you remove it and cap it off with a pipe plug.It should run if the solenoid is the problem,if so you really should replace it but if it is'nt prone to backfiring with it remove you don't have to.You may also have a bad seat switch,confirm this by jumping the plug with a piece of wire to temporarily test it.
Jan 14, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Jun 09, 2009 | Diesel Garden
Garden Logo
439 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
