Question about Miller Welding Tools
I have a Miller Bluestar 185. Will not start with key. Put a new battery in it and it pull starts fine but won't with elec start?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Check if 12v go on solenoid of starter when you turn key to start,mesure 12 v on starter when you turn key to start
if voltage drop to few volt,wire or connection are bad
Posted on Nov 24, 2012
3 Suggested Answers
  • 24 Answers
SOURCE: need to remove a 9 hp engine from a miller
Front panel and stator must be removed first,then separate rotor from engine.
Posted on Sep 18, 2009
SOURCE: I have a Miller Bluestar 2E. It welds fine with
I have a miler bluestar 2e Engine will not start it will barely turn over put in new battery still does the same. Help!
Posted on Dec 06, 2009
Anyone know what spool gun I would use on a miller syncrowave 300(s) welding machine. I think it might need an adapter but not sure.
  • You can contact direct, but here are some links.
  • Miller Spool Guns for Aluminum and MIG Welding - MillerWelds https://www.millerwelds.com/accessories/guns-torches/spool-guns Spool Guns. Spoolmate™ 100 ... Reliable direct connect Spoolmate™ 150 spool gun provides 20 ft of cable reach and accessibility. ... Miller respects your privacy ...
  • AD/4.6 Syncrowave 210 Series - English - Miller https://www.millerwelds.com/~/media/miller electric/imported mam... · PDF file Syncrowave ® 210 Series TIG/Stick/MIG ... Miller Electric Mfg. Co. ... Spoolmate™ 100 Spool Gun #300 371 Includes 12-ft. (3.7 m) ...
  • Miller Spoolmatic 30A Spoolgun 130831 - Cyberweld.com store.cyberweld.com > ... > Miller Spoolguns & Spoolgun Adapters
    • 5/5
    • 11 RATINGS
    • $1,013
    Miller Spoolmatic® 30A Spoolgun is the professional's choice for ... connect to a Miller 300 pro we would ... spool gun plugged into our Miller ...
  • Manuals & Parts - MillerWelds https://www.millerwelds.com/support/manuals-and-parts ... operations/setup information, and maintenance to troubleshooting and parts lists, Miller's manuals provide detailed answers to your product questions. ...
  • Re: Miller syncrowave 180sd & MM 185 w Spool Gun weldingweb.com > ... > Shop, Trade, Sell Forum
    • 3 POSTS
    • FIRST POST: 2013-04-19
    2013-04-25 · Re: Miller syncrowave 180sd & MM 185 w Spool Gun ... The Syncrowave has about 300 hrs. run time and 350 Arc Starts ... Miller syncrowave 180sd & MM 185 w Spool Gun
  • Spool Gun Hookup Chart - MillerWelds https://www.millerwelds.com/.../spool-gun-hookup-chart Find spool gun hookup information for Miller welders. Determine which spool gun works with each ... Spool Gun Hookup Information. ... Millermatic® 300 without Meters:
  • Spool Gun Hookup Chart MillerWelds
    Jun 10, 2016 | Miller Welding Tools
    Miller bluestar 6000...generator works great...welding seems stuck on max amps...dial doesnt seem to change amp power...bogs engine..less than 150 hours...ideas???
    could be a faulty power control swotch
    I am inclined that the voltage regulator the controls the amp out put is faulty
    Take it in for a specialist diagnosis to a welder repair shop
    Nov 02, 2015 | Miller Welding Tools
    Is the fan blade on the generator repairable
    Anything can be replaced, check the spec of the part and see if you can track one down. Refitting may be an issue depending on how it is situated nut it can be replaced almost certainly.
    Jun 08, 2015 | BlueStar Miller Bluestar 185 Dx Gas...
    My miller blue star 185 wont idle up when you start welding
    Check your idle control module,
    take the roof off of your welder, located at the top right of the inner control panel, it is the little red box with multiple white leads connected to it and labeled with alphabet letters.
    pull the connectors, insure they are clean, reconnect them, start your welder and see if that corrects the problem, if not, you will need to purchase a new idle control module
    Feb 25, 2015 | BlueStar Miller Bluestar 185 Dx Gas...
    I have a 2006 new beetle, just put in a new battery about a week ago. It drove fine. My problem is, the car won't start when i turned the key. I tried many attempts, but just won't budge. Is
    Hi there, with this kind of problem in general, you have to look on any source from where your battery is being drained. Check your new battery if it is drained again. If the voltage is below 12V means there is a close circuit that is using your battery while it is stopped. Recharge your battery and try starting your car or ask a friend to jump your car. If it wont start check your starter motor. Another factor to think of is maybe your alternator is not charging your battery.
    Mar 26, 2013 | 2006 Volkswagen New Beetle
    I have a Miller Bluestar 2E. It welds fine with the high idle on. It won't pick up with the high idle off. What could be the problem?
    sounds like govenor is not functioning properly.
    amp draw should engage unit out of idle with engine at normal operation temp.
    May 09, 2009 | Welding Tools
    Welding Tools Logo
    291 people viewed this question
    Top Miller Welding Tools Experts
    Robert Lee
    Level 1 Expert
    Kory Ronning
    Jose Velazquez
    Jose Velazquez
    Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
