I'm having a problem with my Saeco Easy machine. The red warning light is on but no matter what I do it stays on and the machine will not make espresso. The hopper is inserted correctly, it has water and beans but it's not working. I've removed the bottom catch tray for the 5 seconds while the machine was on but the light didn't reset. Am I missing something or is it just broken?
SOURCE: Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
SOURCE: Saeco Espresso machine - Empty drip tray (all the time)
Clarification: It complains constantly. Even when I empty the drip tray, which is already empty, put it back in (empty) - it still wants me to "empty the drip tray" again. Sometimes - if I'm lucky - I can brew 1 espresso before it wants me to empty the drip tray.
Thank you for your assistance!
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
It is possible that the grinds chute is blocked, remove the brew unit and check the chute from the grinder chamber, make sure that it is not blocked with coffee grounds.
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Try to get 2-3 cups of water from hot water knob
