What is the cable not supplied with the rt151 that i need to install ,the cable plugs in the front of amp then the out audio of the tv of th
The unit did not supply the cable the plugs into front of amp then plugs into out audio of the tv a model tc132c3 panasonic
    Sergeant:
  • 238 Answers
Typically, the cable would be a mini phone jack cable. The connectors would be called either 3.5 millimeter or 1/8" phone plugs. Some cables have the 1/8" jack on one end and the other end might have 2 RCA connectors. The RCA connectors are also called phono plugs. According to the specs I have found, the system has both phono jack and a mini phone jack. The cheapest solution is a 1/8" stereo male to 1/8" stereo male mini phone cable. Here is a link to a place that several types to choose from, as well as pictures:
http://www.cablesforless.com/Sub-Mini-35mm-Stereo-Phono-Cables-C13.aspx?gclid=CMX96M_aq7MCFaOaPAodC1QAyQ
Posted on Oct 31, 2012
4 Suggested Answers
  • 10 Answers
SOURCE: Panasonic SC-HT500
Not really an option to modify cable.Connections inside subwoofer and main unit are difficult to work with.Common problems with dvd are laser/traverse deck failure and dvd tray ailgnment.You can run a seperate Dvd player by using the Tv or Tape audio input in the receiver and run the Video cable direct to TV.
Posted on Apr 05, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: what cables are needed to connect rt151 to PC
This picture is from the RT151 manual (which you can find here if you need it):
If you use the front panel LINE IN jack (#6), you need a cable with a 1/8-inch stereo plug at each end. One end connects to your computer's line out jack (always available on the rear, and also on the front panel on many computers), the other end to the RT151.
The other option is to use the rear panel AUX IN connections. Then you'll need a cable with the 1/8-inch plug on one end, and RCA plugs on the other. If you're going to want to leave your computer connected to the stereo system permanently, this would be the way I recommend. You won't have a cable plugged in to the front all the time.
Thanks for using Fixya!
Posted on Dec 04, 2010
Testimonial: "Brilliant!! Thanks very much for a quick response!!"
  • 569 Answers
SOURCE: I have a Panasonic Model TC-p42X1 TV hooked up to
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Posted on Feb 03, 2011
INSTRUCTIONS FOR (EMERSON DVD/VCR) MODEL EWD2004
it sounds that your tv has no audio/video input jack so you don't have place to insert the rca cable. what you need is an RF converter where you can hooked up the 3 cable wire for audio( L/R), video.then the other end you need to use an RF plug with wire that you can plug into the RF tuner of the tv and the other end to the RF converter.hope this can helped thanks for using the fixya.
Aug 12, 2012 | Televison & Video
What cables are needed to connect rt151 to PC
Dec 04, 2010 | RCA RT151 Theater System
My Notebook doesn't recignize my hdmiflatscreen tv and vise versa
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally. At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Mar 07, 2010 | Emerson EWL2005 20 in. LCD Television
Will this support tv viewing through propr cables so I can use it as a monitor for my computer with vga to rca high resolution cables
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 05, 2010 | RCA TruFlat 27F520T 27" TV
S-video conection with pc
Mar 05, 2010 | Toshiba CX36F67 36" TV
How do i hook up my computer to my mitsubshi ws-48413?
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go. At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
Mar 03, 2010 | Mitsubishi WS-65413 65" Rear Projection...
Do not know how to install to cable box tv
Feb 16, 2010 | Curtis CMD1000 DVD Player
Does anyone know how to set up an old nintendo game
I am assuming you mean a nintendo entertainment system (NES)
You Need:
The gray master console
At least 1 controller
Power supply
RF Switchbox (Must be an auto switchbox) or an A/V Cable with RCA ends
The power supply & RF switch plug into the back of the grey master unit. Hook the RF switch up to the cable connection on your TV. (If using the A/V cable - it plugs into the side of the master unit & into a video in - yellow plug/audio in - white plug) Plug in the power supply. Make sure a controller is plugged into the 1 outlet on the front. Make sure a game cartridge is inserted & locked in (You push it down). The TV needs to be on whatever channel the switch is set on if using the RF switch (Channel 3 or 4). Turn on the power & it should work
Jan 03, 2010 | Nintendo DS Console
Need help hooking up my duraband surround system to my tv and dvd,tv has 1 set of holes in front and dvd player has in and out
plug the dvd audio into the amp and video to the tv if you have an output on your tv plug it in too.the amp. plug cable in back of tv
Jun 24, 2009 | Durabrand 5.1 Surround Sound Computer...
54 people viewed this question
 Grubhead
Grubhead
