Question about HP 413670-001 - HP Compaq nc6320, nx6310, nx6320 Series Intel Chipset Full-Featured Laptop Motherb... Motherboard
Show memory dumping and resart - HP 413670-001 - HP Compaq nc6320, nx6310, nx6320 Series Intel Chipset Full-Featured Laptop Motherb... Motherboard
    Sergeant:
  • 250 Answers
It would help if you mentioned the OS version. Blue screen/memory dump is usually some driver or hardware error. First, make sure you run windows update to get windows up to date. Second, get all the driver updates from the hp/compaq site. Third, run the system file checker. You will need the Windows CD unless your system has a recovery partition. To run thew system file checker:
Start>Run>type in sfc /scannow <enter>
Note the space between the sfc and the forward slash. Also, note the two n's in scannow.
Posted on Oct 31, 2012
My nokia mobile 2700-2 after resart still hang when showing clock. keypad not work how to solve problem? plz help me
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Aug 13, 2012 | Nokia Classic 2700 Cell Phone
Physical memory dumping
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
I have a problem for my msi laptop.all application for camera are shows black screen.i used windows 7 operating system.before same this happen.i used camera firmware its working.but now i use again,but...
hi kwitibo930
  • first a fall un-install the web camera software from your laptop...
  • Then check the whole system as virus security
  • Then resart it
  • Then install msi web camera software itself...
  • Then check it working or not..
  • If it not means go to www.msi.com
  • And enter your model name
  • Enter what you want the cam driver...
  • then install it and resart your system immediately
  • Then it worked clearly try it..
  • Thank you...
Jan 01, 2011 | Computers & Internet
How to stop dumping memory to disk errer
Hi rakib_050415
The problem you are having doesn't have anything to do with the motherboard. When Windows dumps out and starts that memory to disk, then you either have a bad hard drive or bad memory that's causing you the problem. Once in a while it can be the CPU, but I'd say 1 out of 20,000. To find out I'm going to send you to two different places to download some software to test both. First to test your memory go HERE. They are all free programs, so pick which one you want and download it, and read the instructions and run it. Then to test your hard drive. After you've finished that test, then go to HERE and again, download whichever one you want and follow the instructions and run the test. It's not going to repair either the memory or hard drive. You will need to go out and replace it. Now if you find that you've run both tests and neither show and problems, then you have something else wrong with your computer software, not hardware. It could be something you just recently downloaded, that has messed up your registry. The list can go on, but for now, try the most probable before you jump into insanity.
Good Luck, and please post back what your results are.
Thanks
Mark
Jan 31, 2010 | Intel Computers & Internet
Beginning dump of physical memory
This could be pretty complex. The ATAPI.SYS file controls the Hard Drive and CD-Rom Drive. I would recommend reading this MS TechNet article:
http://support.microsoft.com/kb/822051/ The article says that it's not uncommon for the problem to be caused by faulty memory or by problems in the mass storage controller subsystem, which makes sense since atapi.sys (a mass storage controller system file) is noted.
If you have multiple memory cards in the machine, it might not be a bad idea to take one out and try again. If the fails, keep swapping out memory cards until we either solve the problem, or elimite that as a cause.
Apr 21, 2009 | Computers & Internet
KERNEL_DATA_INPAGE_ERROR (BEGINING DUMP OF PHYSICAL MEMORY)
The fix for your issue is to reinstall OS if software is availiable you can't fix this issue I have come across this error with to many customers
Mar 18, 2009 | Computers & Internet
Physical dumping of memory
Hi!
Take out the RAM and clear the fungus..
fix the RAM and start with safe mode....
Bye & Take care...:)
Mar 13, 2009 | Microsoft Computers & Internet
Automatically restarted problem with mother board
enter the bios and enable the usb funtion memory dump is usally caused by bad data or memory sticks have you upgraded the ram if so check the speed match it as close as possible
Dec 19, 2008 | Computers & Internet
HP 413670-001 - HP Compaq nc6320, nx6310, nx6320 Series Intel Chipset Full-Featured  Laptop Motherb... Motherboard Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
