Question about Canon SD1400 IS / Digital IXUS 130 Digital Camera
Lens error E32
ASK AN IMPROVEMENT SOLUTIONS
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Posted on Nov 01, 2012
Question about Canon PowerShot SD1300 IS Digital ELPH Camera
common problem ask the photo shop.
1- the powershot is set on when the battery is to low
then the lens will be blocked due to less current.
2-the lens is blocked bij a little tiny sandpiece.
Jan 24, 2018 | Canon Cameras
How to fix E32 error on canon powershotSD1300IS
This error normally comes when your Canon camera lens gets stuck in the barrel itself. There are some steps which can be followed to resolve this problem which as follows,
STEP 1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
STEP 2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
STEP 3: Just push and pull the lens slightly as it extends automatically.
STEP 4: Now when the lens is in the hard surface power on your camera.
STEP 5: Try to hit the camera softly beside the lens which might solve the issue.
You can try to format the memory card completely and then reinsert to your camera which might be the issue at times.
Sep 14, 2014 | Canon PowerShot Cameras
No picture when i use camera then will appear the e32 error then shotdown
lens may be slightly experiencing a focus error . try cleaning the lens and contacts .
or set the switch to manual focus
Jan 27, 2014 | Cannon Cameras
When i turn my camera on it works fine, but after being on for a few minutes it will say E32 on the bottom left hand corner of the screen and then shut off. i would REALLY apprecitate some help !!!
Hello! Welcome to FixYa
If you are facing error E32 it means lens becomes stuck in the barrel. There are some solutions you can try to fix but the probability is that you will have to get it fixed by a professional.
First connecting your AC adapter or USB cable.Try holding the shutter button while switching on the camera. Look at the lens and if some of the lens circles is misaligned or not concentric then try wiggling it. Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
If your camera is still under warranty then best solution is to take it from where you purchased before trying any of these steps.
I hope this solution helps you.
Thank you for using FixYa
Aug 21, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Erreur E32
If you're having E32 errors, it means that your lens is stuck in the barrel. It's not an uncommon error, but the best resolution I can suggest is to bring it to a professional as a last case scenario, but here are some tips:
1. Try holding the shutter button while switching on the camera
2. Try connecting it to your USB adaptor, usually it pushes the lens in and out.
3. Look at the lens and if some of the lens circles is misaligned or not concentric then try wiggling it, turn your camera off and on.
May 24, 2011 | Canon Powershot A490 A495 Sx210is
E32 error. Canon SD 1300IS Camera shuts down.
E32 error means lens has become stuck in the barrel
  • First connecting your AC adapter or USB cable.
  • Try holding the shutter button while switching on the camera
  • Look at the lens and if some of the lens circles is misaligned or not concentric then try wiggling it (while holding camera lens down)
  • Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Other than that take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty best solution is to take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
I hope this solution will helpful for you.
Thanks and Keep Visiting FixYa
Mar 20, 2011 | Canon PowerShot A570 IS Digital Camera
Sd1400 canon camera error e32
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sep 10, 2010 | Canon PowerShot SD1400 IS IXUS 130...
E32 error with canon ixus 130
I have purchased recently canon ixus 130, the camera automatically shuts down after some 30 sec& shows a messege 'camera error,restart camera will autometically shut down error
E32.'
Jun 06, 2010 | Canon PowerShot SD1400 IS IXUS 130...
Canon SD1400 IS / Digital IXUS 130 Digital Camera Logo
134 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
