Question about Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 no longer see's the KCA-BT200 after doing a reset.
I have the Kenwood KVT-512 and had it professionally installed. For the most part I've been very happy ( would love to be able to see iphone information on screen for songs being played through bluetooth). Yesterday I was driving home and the screen stayed open after turning the engine off. I turned my Honda Element back on and the CD player did not turn back on. Not knowing what else to do I held the reset button on with the engine still on and after several seconds my CD player rebooted with the time resetting to 12, the subwoofer off, and the firmware no longer the latest. I found fixes for all those things except for the Bluetooth Setup. I have been through the settings a million times and can not find the menu that I initially used to pair my phone with the receiver. In the menu options i don't see a single bluetooth menu. Only the Bluetooth option on the audio select is there. This however has no option to set up. REALLY CONFUSED!!!! Please help!
4 Suggested Answers
C13295
  • 128 Answers
SOURCE: KENWOOD KVT-729DVD & KCA-BT100 BLUETOOTH + KCA-IP300V
Try this. This is the Kenwood support. Hope this helps. :)
By Phone
(310) 639-9000
or toll free 1-800-KENWOOD (536-9663)
Posted on Jan 13, 2008
  • 4 Answers
SOURCE: Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Posted on Jul 16, 2009
  • 4 Answers
SOURCE: Kenwood KVT-512 with bluetooth setup troubles
I cant conect mi huawei p8 on kenwood kca bt200 i forgot pairing code ...help me please help help help
Delete the registration and then check out pages 12 and 13 of the user manual, below.
http://kasc4.s8.novenaweb.info/files/prod/1028/5/KCA-BT200(EN).pdf
Sep 05, 2016 | Kenwood Radio Communications
By Phone
(310) 639-9000
Jan 13, 2008 | Kenwood KVT-617DVD Car DVD Player
How do I make my kdc-mp242 bluetooth discoverable?
In order to use bluetooth with your receiver, you need to purchase the Kenwood KCA-BT200 Bootooth Interface. These are readily available online and can be had for $100-$150: Kenwood KDCMP635 KDC MP635 KDC MP635 50W 4 MP3 WMA AAC CD Receiver cheers
Mar 15, 2011 | Kenwood KDC-MP242
I plug my ipod to the stereo but my stereo screen still says discconected
you have to go to the kenwood site and download the firmware update go to this page http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
after you download the file unzip it and burn it with either nero or roxio, as a data file insert the cd on your kvt-512, if it reads DISK ERROR, press the reset button on the front of the stereo, once the screen comes back up select the DVD function, the system update should start from there. let it finish once it does then you'll be able to plug in your ipod. oh and ofcourse for this you should know that you need the ipod adapter, depending on what you want to do with it for instance i have the KCA-iP300V which allows me to view videos from my ipod as well.
Jan 27, 2010 | Kenwood KVT-512 Car DVD Player
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
How do i connect my itouch to kenwood kvt-512???
Hi there! You need a Kenwood KCA-iP300V iPOD VIDEO DIRECT CABLE.
Feb 09, 2009 | Kenwood KVT-512 Car DVD Player
Have a new KCA-BT200 and when I try to connect the bluetooth it keeps disconnecting. If it helps, the Navigation system is KNA-G510
ok first u have reset the KCA-BT200,to do that remove your car battery cables for 3mins and reconnect your battery cables,
by lil_ti2002@yahoo.com
Jan 20, 2009 | Kenwood KCA-BT100 Wireless Headset
Cant get my bluetooth to work
Every thing you need is at this link, read & act carefully and please don't ask silly questions.
http://www.kenwood.com/bt/support/143to160/groupE/eng.html
Nov 29, 2008 | Kenwood KCA-BT100 Wireless Headset
How do i set up my bluetooth for my kenwood kvt-512. im trying to find the bluetooth app in the settings
The Kenwood 512 works with the Kenwood KCE-BT200 module. You need to have this box plugged into the main unit to work. If not, then Bluetooth will not be available. When you do have it connected, use your cellular phone to initiate the connection. when prompted on your phone for a passcode, it will be 0000. After successfully pairing your phone to the unit, you can access the telephone menu by holding the "FNC" key on the front of the Kenwood or pressing "TEL" from the source screen.
Aug 11, 2008 | Kenwood Car Audio & Video
Can the firmware on a in dash kenwood dvd be change
Visit www.kenwoodusa.com for latest firmware updates. Some of the updates are specific to map software (Garmin for KNA-G510) or bluetooth (Parrot for KCA-BT200) only.
Aug 10, 2008 | Kenwood DNX7100 Car Video Player
Kenwood KVT-512 Car DVD Player Logo
47 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
