Question about GE Security Simon 3 Wireless Home Security System
Programing sensor delay
I somehow lost the sensor delay on one of the sensors, I can not seem to find which option in the program to put it back on.
There is no option for delays on this panel. You have to reprogram the sensor.
Posted on Jan 13, 2009
Why is it that when I switch off the heater the fan stops instead of the fan keeping going for a couple of minutes like it use too it now turns off at the same time can anyone help?
Did you replace the thermostat? The feature may need to be programmed into the thermostat.
Some heaters have a sensor, a time delay, this sensor is a temperature sensor wired in the blower motor control circuit, the sensor senses space by the heat exchanger.
When this sensor is sensing hot, it activates the fan and when the sensor does not sense hot, it deactivates the fan. The sensor seems to not be controling the fan anymore but the thermostat is.
Jan 06, 2015 | Heating & Cooling
How to ARM and Disarm a self contained ALARM system
An alarm that only sounds for a couple or three minutes, easily defeatable by way of crowbar on plastic? come on.
Nov 30, 2014 | Cars & Trucks
Entry delay is set correct but I want it to call out more quickly when the alarm actually goes off. It seems to wait too long. Do the entry delay and the actual alarm call out delay always the same?
Installation manual is here:
http://www.sdilink.com/GE%20Manuals/Simon%203%20Install.pdf
Programming starts on page 17.
Dialer Delay is option 17 on page 29. It's default setting is 30 seconds.
To set Dialer Delay, press:
1.Add
2.Option #
3.17
4.Use the numbered keys to enter the time 005 -
254 seconds (all entries must be 3 digits).
5.DONE
To turn off Dialer Delay, press:
1.Delete
2.Option #
3.17
4.DONE
Hope this helps.
May 10, 2011 | GE Security Simon 3 Wireless Home Security...
Our sensor bar was cut so we bought a wireless sensor bar, it worked fine on our tv we had because we sit it on top. Now we have purchased a flat screen tv and have to sit it at bottom of tv now there is a...
That isn't a problem with the sensor bar. All the sensor bar is a light emitter, it has a series of infared LED's inside at varying angles. It seems that the problem lies within the radio interference between your WIii more and the Wii. Try moving your Wii away from the TV and maybe even changing the batteries in the Wii mote.
Mar 28, 2011 | Nintendo Wii Console
I bought the Wii active 2 program and most of the program works fine but when I do exercises that involve the stretch bands and bending over the program keeps telling me to lower my arms when they are as...
I understand that it will work without the sensor bar. But, the reason why there is a sensor bar is that it needs to read the activity that is happening around it. It worked without the sensor bar while you did some exercises but it didn't when you bend over because the wii needs more sensory activity with that certain movement.
The functionality of the wii in detecting the movement is not full when the sensor bar is removed. I suggest you put in the sensor bar while doing all the exercises. If it doesn't work, just let me know by leaving a message in this thread.
Thanks,
Carlo
Feb 24, 2011 | Nintendo EA Sports Active for Wii
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
Dec 08, 2010 | Behringer Rx 1202fx 12 Channel Line and...
Both key fobs stopped working at the same time on my 2000 venture. Went through the reprogramming process a few times and it seemed to take...but the fobs still do nothing. Can you turn the keyless option...
under the dash on the criver side by tour obd2 sensor is the remote keyless sensor. Unpug it and for 30 seconds and plug it back in If that does not work, you need to replace the sensor
Aug 09, 2009 | Chevrolet Venture Cars & Trucks
How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
\ 0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Dec 31, 2008 | Honeywell Heating & Cooling
Still wondering if there is anyway to get my computer back to the factory settings. I dont have a recovery disc and have somehow lost my microsoft word program which I need desparately. I am not the...
you can restore your system to some back date where it's working fine through system recovery option, for this go to program - accessories - system tools - system restore option.
then select some back date where do you think your system is ok
Oct 10, 2008 | Gateway Computers & Internet
Dropped calls when cordless phone plugged into it.
I have solved this problem several times by using a splitter at the telephone jack instead of the XDP port on the phone. The extension is programmed to share the port isn't it? That is in program 600.
Aug 21, 2007 | Panasonic KX-T7633 Corded Phone
GE Security Simon 3 Wireless Home Security System Logo
52 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
