Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
How do I take the cover off samsung 930B monitor
My monitor went dead, so I need to replace the bulbs and possibly the inverter (?) I unscrewed the three screws in the back of the monitor, but the back won't come off without some "violence". Don't want to break it, but don't know how to get it off either. Who knows?
  • PerttiK Jan 04, 2009
    Thanks!!
  • 105 Answers
The front and back covers snap together. Some come apart easily others are very reluctant and will break some of the retaining clips as you pry the front and back apart. Usually this does not result in a problem as there are enough retaining clips to hold it back together.
Most of these do not need bulbs. Usually just replace the power supply electrolytic capacitors that are bulging.
Monitor Mike
Posted on Jan 04, 2009
How do I replace the inverter in a samsung syncmaster 930B?
The 930B and the 710T use the same power supply/inverter boards. Below is a link to a repair guide for the 710T unit that should get you going in the right direction.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-syncmaster-710t/
Jan 27, 2013 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Check signal cable
Check if the monitor is not working by connecting this monitor to another computer.
If the monitor woks on another pc, then the pc is the issue and not the monitor.
If monitor doesnt work on the other pc, then it's the monitor that needs replacing.
I hope this helps you :)
Jul 13, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I have a samsung syncmaster 930b that has no picture but power light flashes and when I press the power button it will not stop flashing. what do I need to do?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 23, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Flashing power light, no image. Is my monitor dead?
More likely to be bad caps in the power supply, it can also be bad Inverter circuits, bad lamps, bad inverter transformers. Look at the caps first. See exampleof failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 10, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I have a power light on my Samsung syncmaster 930b but no image at all is this just a lamp issue or is it a dead moniter.
The problem can be bad caps in the power supply, inverter circuits, or bad lamps. You need to open it up and see, report back what you find so we can help you further, see example of failed monitors due to bad caps, lamps here: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
SyncMaster 930B takes 20 minutes at least to become visable
IT SHOWS THAT THE PROBLEM IS IN THE POWER SUPPLY SECTION OF THE LCD. CHANGE THE CAPACITORS PLACED IN THE POWER SUPPLY SECTION. IT WILL WORK.
DONT FORGET TO VOTE.
Oct 10, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My syncmaster just stopped working one day after i woke up.its black but if you look close enough,you see your desktop. please help=mekondjol@yahoo.com
That means that the inverter is gone.
If you can see the picture by pointing a flashlight on display at close distance, then the inverter must be replaced. The inverter is the power board thet supplies high voltage to backlight lamp.
Regards.
Apr 11, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Sumsung 930b goes dim,and flickers after about 3 min.
This sounds like the inverter has gone bad. If the bulb were bad only, you would see a faint image on the screen with a flashlight.
The problem is on this monitor, it will probably cost about $100 or so to take it to a shop to get it fixed, and that is nearing the cost of a new monitor.
If you are a little bit handy, and can disassemble the monitor, you can replace the inverter. The hardest thing about this, is getting the monitor faceplate open. Just use something firm and softer, such as a nylon spudger (this is something you can find online) or you can carefully use a thin scredriver. You just have to be careful, those cases are really tight.
Here is a good guide for general ideas on how it is done.
http://www.instructables.com/id/Replace-LCD-Backlight-Inverter-on-Any-Monitor-for-/
Paul
Apr 09, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung SyncMaster 191T
You have either a bad inverter board or burned out backlight fluorescent bulb. Very common on this monitor.
Dec 20, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
244 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
