Question about Maytag Refrigerators
I have condensate leakes into the bottom of my freezer and ices up the bottom of the freezer
Condensate from my frost free Freezer portion of my Maytag fridge ends up forming a sheet of ice on the bottom of the freezer.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
YOUR DEFROST DRAIN IS CLOG UP YOU WILL NEED TO PULL THE BACK COVER OFF IN THE FREEZER SIDE AND CLEAN THE DRAIN YOU WILL SEE IT AT THE BOTTOM BEHIND THE FREEZER COVER
Posted on Nov 02, 2012
peyton32034
  • 410 Answers
SOURCE: Bottom of Maytag Freezer Ices Up
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Posted on Dec 16, 2007
aborcass
  • 2651 Answers
SOURCE: Excessive Frost and Ice Build up in Freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 20, 2008
  • 1073 Answers
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Posted on Apr 12, 2008
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
SOURCE: GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Posted on Oct 22, 2009
Leaking water on floor
Remove contents from bottom of freezer. Turn ref/freezer off. Use the handle end of a screwdriver and carefully break up the ice build up from the bottom of the freezer. Find the condensate drain and remove ice build up. Find the condensate drain and remove ice or any kind of restriction from the drain line.
Or you can turn the refrigerator off for a day , mop up the water and blow out the condensate drain
Jan 18, 2016 | Maytag Refrigerators
Water on the bottom of friezer
Hello Geens
My name id Peter. I am a retired field service refrigeration technician.
You have a frozen condensate drain. About every 8-10 hours your refrigerator shuts down for about 20-30 minutes. At this time your defrost heater (Under your cooling coils) turns on and melts the frost off the coils. This condensate goes down your condensate drain. If the drain is frozen, the condensate has no where else to go except on the bottom of the freezer.
The freezer drain is behind the back wall of the freezer. You need to clear the ice out of the drain and put a heat sink in the drain hole.
You may try using warm water and a hair drier, but be ready for a small flood.
You did not give a model number, so I can not tell you how to repair.
Nov 12, 2014 | Refrigerators
Refrigerator is not cold but motor is running.
Hello and Welcome to Fixya,
This is one of the most common problems in most of the refrigeration appliances. What's going on here is that the condensate drain hole in the freezer gets plugged with ice. Once this happens, all the frost melted off the evaporator during subsequent defrost cycles can no longer drain and so spreads out on the freezer and dribbles down and also chokes other components. Here are the instructions that you need to follow inorder to get rid of the problem:
  • Unplug the refrigerator and pull everything outta the freezer, and I mean everything.
  • Remove the bottom panel inside the freezer so you can see the condensate trough in the back of the freezer.
  • Notice that the condensate trough is filled with ice- all that has to be cleared out.
  • Take it easy back there, delicate parts are exposed- don't start hacking at it with an ice pick because there are chances that you'll just end up puncturing the evaporator and you'll turn a simple, inexpensive repair into a majorly expensive one.
  • Use hot water to drain all the frosted ice that is visible.
  • Re-place all the units removed during the process.
  • Once all the ice is cleared away and the condensate drain opening is cleared, you are done.
Best of Luck,
Please do rate my solution, If found helpful.
Regards.
Dec 21, 2010 | Viking DDBB363 Bottom Freezer Refrigerator
THE FREEZER IS BLOWING WARM AIR
Best of Luck,
Regards.
Nov 20, 2010 | Roper RT18HDXKQ Top Freezer Refrigerator
The freezer frosts and ices up so bad it plugs the holes that cool the refrigerator. Then this morning there was a puddle of water in front of it
This is one of the most common problems in most of the refrigeration appliances. What’s going on here is that the condensate drain hole in the freezer gets plugged with ice. Once this happens, all the frost melted off the evaporator during subsequent defrost cycles can no longer drain and so spreads out on the freezer and dribbles down and also chokes other components. Here are the instructions that you need to follow inorder to get rid of the problem:
  • Notice that the condensate trough is filled with ice– all that has to be cleared out.
  • Take it easy back there, delicate parts are exposed– don’t start hacking at it with an ice pick because there are chances that you’ll just end up puncturing the evaporator and you’ll turn a simple, inexpensive repair into a majorly expensive one.
Best of Luck,
Regards.
Jan 25, 2010 | Haier HTQ21JAAWW Top Freezer Refrigerator
My samsung rb 1855sl is having an issue where freezer is not working.
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
FROST FREE FREEZER HAS FROST ALL OVER, AND UNDER THE CRISPERS ARE FULL OF WATER WHAT IS THE PROBLEM. I HAVE DEFROSTED AND UNPLUGED ABOUT A MONTH AGO, AND IT HAPPEN AGAIN.
Your defrost condensate drain beginning in the rear and bottom pan of the freezer has a blockage somewhere between the freezer and through the turns it makes going down to the condensate collion pan below the refrigerator. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 20, 2009 | Frigidaire Refrigerators
The freezer compartment on my fridge keeps icing up over a couple of months. How can i prevent this please.
if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes:
1. low refrigerant
2. no fan
3. too much humid air in fridge/freezer due to door open or bad door seals
4. the condensate drain tube is clogged
if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s).
no air, no fan. Replace
if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional.
defrost solutions:
unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Sep 01, 2009 | Refrigerators
Viking Condensate Freezes
most likely the drain is plugged try using some low pressure compressed air to blow out the tube, yes the heater is what defrosts, no hot gas, other than that the icemaker fill tube could be leaking, freezing the drain.
Mar 30, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerators Logo
328 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
