Question about Dell Computers & Internet
Dell Inspiron 5720
How to get into safe mode. I tried both F8 and F10 but to no avail.
  • Dell Master
  • 7,627 Answers
F-8 is the key, Try to "cold start" the computer, meaning remove the power plug from wall outlet or uplug from computer, remove battery, now replace battery and plug computer into wall outlet. Push the on button while "TAPPING" the F-8 key repeatedly Tap, tap, tap, until you hear a beep or it load the black menu with safe mode options. IF THAT DOES NOT WORK: shut down the laptop,remove AC supply, remove battery. Plug the AC power back in,DO NOT INSTALL BATTERY, Start the machine, without battery installed, and tap F-8 repeatedly. If it still fails, PULL THE PLUG OUT OF THE WALL OUTLET WHILE THE COMPUTER IS STILL RUNNING. NOW PLUG THE LAPTOP BACK INTO THE WALL AND START, THAT SHOULD TAKE YOU TO A BLACK PAGE WITH WHITE SCRIPT WITH OPTIONS YOU ARE LOOKING FOR.
Posted on Oct 31, 2012
parrotheadpc
  • 2600 Answers
SOURCE: dell inspiron 1525 can't start in safe mode just a
Try this windows fix....
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Jan 12, 2010
  • 45 Answers
SOURCE: cant get into safe mode. tried toggling f8/f7 together but nothing
the key to getting into safe mode....tapping F8 (only that key) super fast, not stopping until you hear a beep...and see the option to boot into safe mode.  The most common reason that it will not work is that it is not pressed fast enough or early enough.  You will know that you missed your chance if you see the windows loading screen......start pressing it right away when you restart your computer and don't stop pressing F8 until you see the black screen with the white letters giving you the option to boot into safe mode.
Good Luck!
Posted on May 08, 2009
  • 3278 Answers
SOURCE: where is safe mode option on the DELL INSPIRON
If you select F8 repeatedly, you should display the Safe Mode menu.
Posted on Jul 02, 2009
parrotheadpc
  • 2600 Answers
SOURCE: My dell inspiron 1521 screen goes black!
Yes, most likely the inverter has failed if you can still make out the desktop but the screen is very dim. Below is the link to the service and repair manual for that model.
http://support.ap.dell.com/support/edocs/systems/ins1521/en/sm/index.htm
Posted on Jan 23, 2010
  • 3940 Answers
SOURCE: I want to restore my dell inspiron mini but I dont...
Run PC Restore from the instructions below
http://www.fixya.com/support/r3705089-restore_dell_system_original
If that fails, then you will need an External USB Optical drive to reload windows from using your Dell reinstall media that came with the system.
Posted on May 22, 2010
Cannot get into safe mode dell inspiron 5720
Try booting from your OS (operating system software) CD,i.e. Windows XP, Vista or 7. If that works then you will need to to reload OS.
Mar 15, 2013 | Dell Inspiron 1501 Notebook
My dell inspiron 1454 keeps looping on the boot up screen, then just goes back to the windows has filed to start screen..
Hi Charlotte,
The video doesn't show what you describe. The video shows that Windows is loading. Try booting in safe mode. Here's how:
Power up the machine. When the Dell logo appears, start tapping the F8 key until the Advanced Boot Options menu appears amd choose "Windows Safe Mode." Once windows starts, backup your data just in case. Then try to determine what it was you did last that may have caused the problem. Then try to start normally.
Hope this helps
Randy
Nov 02, 2012 | Computers & Internet
I have forgotten my password to my windows vista Dell 530 Inspiron desktop
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
There is a free boot CD called Hirens. This one command prompt only.
Oct 14, 2012 | Dell Inspiron 530 Desktop Computer...
I Dont Really Know How To Explain It Not Very Technologically Advanced. I Have A Dell Inspiron 1300 Notebook But Do Not Know The Administrator Password. Bought It At A Flee Market For A Good Price But Not...
try start it in safe mode, right after you turn it on you will se options like esc., f1 and f10 at the bottom of the screen, press the f8 key and a menu will show, use the arrow keys to go down to safe mode then press enter, after you are in safe mode go to control panel, users and then change the password, you sould be able to start it in normal mode after that,you will not see the f8 option but you have to press it, if doesn't work try keeping it pressed till the menu shows, be quick, you only have 25 seconds to do this before it starts in normal mode, i hope this helps you...
Oct 05, 2010 | Dell Inspiron 1300 Notebook
When trying to log in it will not except my password. It tells me the handle it wrong. I have tried to log in as administrator will not let me do that either. I doesnt seem to shut down correctly or...
windows has something called the safe mode thru wich u may enter the system. its either of the F8 F9 or F10 keys... try safe mode entry with networking. this will by pass the entire process of logging in if thats all u need. when ur sytem boots up keep tapping these three keys induvidually and ur safe mode menu ll open up
Sep 05, 2010 | Dell Inspiron E1505 Notebook
Hi my dell INSPIRON/640m starts with Dell.com
try hitting the F8 button as it starts to boot you should get a screen with several options see if it will go into SAFE MODE or Last Known good Settings that worked try safe mode first,,,,,Good Luck
Jun 15, 2010 | Dell Inspiron 640m Notebook
How do I get into safe mode on a Dell Inspiron 531. PF 8 doesn't do it?I can only get into Setup with PF2. Otherwise the boot up only goes to the DELL screen and hangs there.
You cant get in safe mode because the PC hangs before windows ever try to start.
Try to press F8 multiple times but right after the Dell screen.
Some computer don't like that you press F8 while the bios is loading and just hangs there, maybe its your case.
Oct 27, 2009 | Dell Inspiron 531S (DDCWGA1_5) PC Desktop
Where is safe mode option on the DELL INSPIRON 1501
safe mode is appear on the screen before the normal windows system. all you have to do is press F8 or Function 8 before the normal system comes up. This procedure is only for technical assistance, whatever any changes on safe mode is your decision. Good Luck!
Jul 02, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron wont start!
try to boot in safe mode thru boot menu pressing F2 or F8 or F10 when prompted on startup it will present u with a screen to select safe mode on startup just go thru safe mode and try using system restore in the Start> All programs> accessories>system tools>system restore try to restore on the earlier date when ur sys was ok see if it helps pls vote if u think i was helpful
if it doesnt help then try changing RAM
Feb 22, 2009 | Dell Computers & Internet
Computers & Internet Logo
1,576 people viewed this question
Alun Cox
