Question about Generac Power Systems Hammering
Generac centurian generator starter solenoid will not disengage after starting
  • James Laughridge Nov 02, 2012
    15 K Centurian Generator- started during a power failure and shut down after 20 seconds or so. On restarting manually, saw sparks coming out of flywheel area just before it shut off. Local dealed replaced sth starter which had after repeated start attemps been damaged. It seems that the sames problem still exist . The engine starts fine but shuts down after a few seconds and we did see sparks again from the fly wheel area. The starter solenoid is staying engaged while the engine is running . Is this a n electrical relay problem or something worse?
    Sergeant:
  • 288 Answers
Take starter out and grease starter gear shaft. then try again
Posted on Sep 11, 2013
Generac 43901 trys to start but get only a buzzing sound
The buzzing sound is most likely the started solenoid chattering due to low battery voltage, change the battery and try again. If it still does it make make sure the engine is not seized and can turn over. Then measure voltage going from the solenoid to the starter, if it is very low change the solenoid
Nov 08, 2013 | Generac Electrical Supplies
Generac generator remote start
si tiene transfer automatico solo poner un swicht en hilo 1N para cortar senal de entrada al generador del utility power que sensa la presencia de voltage en caso de falta arranca el generador en forma de prueba
Dec 19, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
After shutting it down for summer months it will not start, only makes click noise i have a guardian generac 7000kw home standby generator it is not the limit switch
sound like a dead battery, or dirty / bad connection from battery- try jumping it with a car battery-- if that doesn't work, check battery connection, loose or corroded leads.. otherwise it is solenoid or starter or starter switch
Sep 29, 2009 | Generac Guardian 084464 - limit switch
Generac Watchdog 15K, engine will not start
throttle motor or governer board. or control board. your gas line could be to small. check the pressure while its cranking to see if it drops. watch the throttle to see if its moving while trying to crank the generator
Jun 27, 2009 | Generac Guardian 200 Amp Transfer Switch...
Dont have 12 volts to start switch generac guardian ultra source
Have you checked the fuse? Mine keeps blowing the fuse (located on the back of the control panel) with each startup and shutdown or use of idle control.
Jun 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Start runs shutsdown
Typically caused by the fuel line (LP or Natural Gas) having a lot of air in it. Was your generator just installed, or was there any work done to the gas line of the building / generator? Consult local gas contractor / propane dealer / gas company for assistance in purging the fuel line.
A low battery can also cause this as well as the generator is not able to come up to starting speed quick enough. Try placing a stand alone battery charger on the generator and charge the battery. Also check the air filter as well.
OverCrank condition occurs when generator tries to start itself, or be manually started, and the starter spends too much time turning.
This can also indicate failure of the control board. This will need the expertise of generac technician. Call 1-888-GENERAC (1-888-436-3722)
M-F 7am-6pm Central
Mar 29, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Generator will not start
Is the oil sump full? Has it been run with out oil? You can do an amp draw test on the starter. Should be 60 amps or so. Can you roll the engine by hand? If engine turns free pull the starter out and bench test it with jumper cables. Positive cable to cable lug and negative cable on the starter case. Hang on to it, lots of torque. If the stater turns slow or gets hot it is probably bad.
Mar 25, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Hammering Logo
110 people viewed this question
Top Generac Power Systems Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Generac Power Systems Hammering Expert? Answer questions, earn points and help others
