Norelco NT IIe unit does not play just squeals- belt is OK, the motor does not turn. Any ideas or history
Have open on bench- I have no schematics or Service manual. Looks like there are mechanically operated state type switches in the unit. All it does since it came in is in play mode it makes a squealing sound but no play motor movement- no voltage is applied to the motor. The fast wind and rewind do work. The only belt in the unit is fine. This is a motor control or switching problem. This is the first time I have seen one of these. Any ideas?
  • Audio Player... Master
  • 5,017 Answers
The clue is in the motor getting no voltage. A broken switch? Follow the motor leads to the source of where it gets power.
Posted on Feb 25, 2013
  • Sam Palermo
    Sam Palermo Feb 25, 2013
    I will have to work on this a little later as way too many units in my shop to worry about the small portable item that actually was resolved- I have other units of the same type here. I checked this but was not having any schematics to go further.
robotek
  • 1512 Answers
SOURCE: My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
Posted on Feb 14, 2008
  • 142 Answers
SOURCE: Marantz Cassette Deck Model Sd 35 Tape door will not open
It sounds like the drive belts on the deck have broken (not allowing playing, FF or REW) and/or the tape got "eaten" meaning the tape itself has wound itself around the rollers and cannot free itself. I strongly doubt this is an electrical issue. Definately sounds mechanical.
As far as the door not opening, there's usually a hook that holds the door closed. If the unit is mostly disassembled, look near one of the sides of the door for a metal hook. It's normally spring loaded and can be moved manually. That should free the door. If your tape was eaten, it might take some gentle persuasion to unwrap it from the rollers.
Good luck.
Posted on Mar 13, 2008
  • 79 Answers
SOURCE: Tape deck turns on, operation sounds & looks NORMAL- yet won't function
Belts are prone to harden over time, like 10 years. The belt probably broke.
If you don't feel comfortable removing the housing yourself, take it to a repair shop.
Posted on Mar 21, 2008
  • 319 Answers
SOURCE: Nakamichi BX-125 Cassette DEck
Unit probably needs belts. Over time, belts may become slack or decompose into tar-like compound. In this case, the deck will need to be cleaned and belts replaced. Take to pro/tech
Posted on Apr 23, 2008
SOURCE: Denon DRM 740 tape does not play
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
Posted on Feb 12, 2009
Mdg9700 drum not turning
Without the schematic all I can do is go by the general schematic the schematic should be located in the control panel anyway a broken belt will cause the tumbler not to rotate, a bad belt switch, probably not the problem, an open safety thermostat will stop power to the motor, a bad motor of course will cause the problem and lastly a bad relay on the control board will do it, remember I do this everyday so for a DIY it make pose a bit of a problem to know these part locations or how to disassemble the unit
Mar 23, 2014 | Maytag Neptune MDG9700A Gas Dryer
Green light for flash doesn't come on
usually, Polaroid resists letting anyone but an authorized service center mess with their stuff.
Feb 17, 2008 | Polaroid MiniPortrait 203 Instant Camera
Cassette tape stops after 5 seconds
This can be due to state sensor switches being dirty or a bad loading mechanism belt. These are delicate type units and are not easy for a regular owner to service. Best to bring it to a Service Technician. My shop did 6 DAT machines last month.
Oct 26, 2013 | Sony PCM-R500 Single Dual Cassette Deck
KENMORE 106.53644300 ice maker type 2 with front door dispenser. ice maker stopped making ice, than 3 days later started again then stoped, day or so later ran again then stopped. I removed the unit put...
That is a Whirlpool module type ice maker that seems to have has been so strict with their information I will need to give the manual's another way about a 5 year life span. I have some manuals but because Whirlpool stopped letting people post what they believe is their property. I guess I need to only understand but if I place them here I will lose my subscription. Click Here=> My E-Mail and I will send it to you. May have to fill out the capsha first. Below is what I am talking about as far as how they work and yes I have the schematics and tech sheets, I will look to hear from you, Thanks, Sea Breeze
Click Here=> 8201515 Ice Maker Module
May 05, 2011 | Kenmore Refrigerators
I've owned a Roland AC-90 acoustic guitar amp for 8 months and am having problems with the XLR mic preamp. There is some very low-level output with the volume fully advanced, and with an external...
I don't have the exact schematic... however sometimes they have RF bypass capacitors to ground on the balanced input lines and one side gets shorted. The schematic I do have is for an AC100. It shows a rather unconventional input circuit. You can download it here and it MIGHT be close to your unit:
http://elektrotanya.com/roland_ac-100ut.pdf/download.html
I note that this unit does NOT have Phantom power so you CANNOT use a condenser type mic with it unless you use a preamp with Phantom power... Maybe that is the problem?
Feb 16, 2011 | Roland Ac-90 Acoustic Chorus Guitar Amp...
No control of speed on bench grinder,need schematic
Unless the motor is a brush type universal unit, there is commonly no way to change the speed of an induction motor. There are AC motor speed control units available, but cost more than the grinder as they change the frequency as well as the voltage. There are speed controllable grinders available that use brushes so that simple electronics can control speed. Hope this helps!
Dec 08, 2010 | Craftsman 6" Bench Grinder with Lamp
I have an Abbott & Ashby 200mm Industrial Bench Grinder - CS-8GCM I need to change the sanding belt and am unsure how to do it, can you help?
Remove/open cover on the right side of belt assembly housing. push downward on tracking knob left side top of unit.Belt is spring tensioned to remove slack.Push down remove old belt,push down again for new belt.With belt running adjust belt track(centering) by turning knob,top of unit,toward or away from you,Arrow on inside of new belt governs direction of rotation of belt.
Jun 09, 2010 | Sander 6" Bench Grinder 2" Belt Combo...
I have an old 2 piece bench grinder that was wor...
Could be a belt tension issue. Try tensioning the belt by moving the motor and wheels farther apart by reanchoring the units,or,spanning the gap between units with a series of wood blocks and shims(wedges).Be careful with tensioning. Always manualy move the belt,unit unplugged. There should be some deflection(play) in the belt when pressed upon with a finger.
May 20, 2010 | Grinders
Free wiring schematics for deh-p980bt
www.pioneerelectronics.com/.../ci.DEHP980BTOperationManual.Protected - United States http://www.nodevice.com/manual/pioneer/page38.html
http://www.user-manuals.com/advanced_search_result.php?keywords=deh-p980bt+service+manual&forward=plist You need a service manual, they always have schematics. top is a user manual, the other two are service manual sites.
May 19, 2010 | Car Audio & Video
Toshiba M115-S1061, replaced screen & inverter still not working
I have a factory service manual with, parts lists and schematics. It is a PDF so I don't have a link for you but you can contact me at foxmulder616@gmail.com
Apr 29, 2010 | Toshiba Satellite M115-S1061 Notebook
73 people viewed this question
 Grubhead
Grubhead
