Question about LG DS420 DLP Projector
Hairline crack on projector image
Hi there - I have an LG projector which works fine, but displays a wavy hairline crack on the projected image (I presume this is cracked lens?) If you are able to diagnose, fix and let me know where can buy replacement LG lens that would be great! Ben
Blue streak appearing on screen after a while that its been on
Sounds like either a hairline crack, or some image burning. Image burning is very common on projection televions, and are nearly impossible to fix. It could also be heat related, since it only happens after a while, so you could try leaving the TV unplugged for a few days and seeing if that helps the issue.
Mar 01, 2011 | LG RU-52SZ30 52" Rear Projection...
When I plug in the projector to the mains and to the computer then start the projector followed by the computer, the projector projects the image of the windows start up screen but once windows has started...
Hi ;
  1. click right botton on your desktop
  2. choose Nvidea control pannel
  3. configure multiple displayer
  4. choose the second displayer projector and apply the change
Oct 19, 2010 | Acer PD113 Multimedia Projector
I have a hairline crack circuit board directly under the tuner,
it can be jointed, you have to clear the upper coating of circuit board where the crack is. & reconnect all the tracks by means of micro soldering gun.
Mar 11, 2010 | Televison & Video
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
Jun 29, 2009 | InFocus LP 70 Multimedia Projector
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
Wavy Video output from Marantz sr5600 Receiver
are you using component inputs s video rbg or hdmi?
Jan 31, 2009 | Marantz VP15S1 Television
Boxlight cp-310t won't display image
loose connection. possible crack on main board. needs to be sent in to have a look at.
Aug 16, 2008 | Boxlight CP 310t Multimedia Projector
CRACKED
The Stress of impact on the imaging forming unit that is directly behind the projection lens has a flat glass surface. If it is cracked the stress cracks would project with any image because they are on the same plane as the image
Nov 22, 2007 | BenQ MP610 Multimedia Projector
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
LG DS420 DLP Projector Logo
35 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
scj103
Jaime Hernandez
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
