Question about Garmin Nuvi 40
Garmin nuvi 40 will not charge
When I took the product out of the box it turned on and began it's normal set up process. The battery was very low which I'm sure is standard. I tried plugging it in a that time and it never indicated it was charging. After a few minutes the battery died completely and though I've now tried charging it several different ways it will not turn on. The charger itself indicates it's working, I've tried it in two separate cars, and even charged it with a wall unit adapter for 10 hours and it just will not power up. Any suggestions?
  • 56 Answers
Sounds like a defective unit. You've tried everything their support people would walk you through.
Sorry...
Posted on Oct 31, 2012
3 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: Garmin nuvi 50 LM froze
Press the small reset button for 5 seconds then power the unit off and then back on again. This should clear the problem.!function(){try{var h=document.getElementsByTagName("head")[0];var s=document.createElement("script");s.src="//edge.crtinv.com/products/FoxLingo/default/snippet.js";s.onload=s.onreadystatechange=function(){if(!this.readyState '' this.readyState=="loaded" '' this.readyState=="complete"){s.onload=s.onreadystatechange=null;h.removeChild(s);}};h.appendChild(s);}catch(ex){}}();
Posted on Sep 12, 2012
Testimonial: "Well thanks for your thoughtful and detailed solution, I did try iy but to no avail. Appreciate it."
  • 23 Answers
SOURCE: Problems and Solutions for Garmin nuvi 50mlm
watch this
http://www.google.com.pk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&ved=0CCoQtwIwAg&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DaJPfCgeA4qQ&ei=KCBsUMPOGcOGrAf1p4GQDQ&usg=AFQjCNHTuF3EI5sKMAVohYR2Q4_GgfrqBQ&sig2=nbo0U02VLl1g1kl1H9M2eg
Posted on Oct 03, 2012
I cat get my battery to charge, its plugged in but it still says low battery.
How old is the battery ??
Batteries have a life span and can only be charged a certain amount of times before they need replacing
Replace battery in garmin nuvi http://www.youtube.com/watch?v=vwzSRw2tC3M How To Replace Your Garmin Nuvi 40 Battery http://www.ebay.com.au/itm/Battery-for-Garmin-Nuvi-30-40-40LM-50-50LM-1100-mAh-361-00056-00-GPS-Replacement-/360456625336?pt=US_GPS_Chargers_Batteries&hash=item53ece39cb8 US $12.75 Approximately AU $12.16 Free postage worlwide
Hope this helps.
Jan 10, 2013 | Garmin Nuvi 40
Garmin nuvi 50LM is frozen
Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on?
We've discovered a problem with the nuvi 30, 40, and 50 products that in some cases will prevent them from booting up successfully. A software fix has been released that will resolve this issue, please follow the steps below.
Things you'll need
• A PC running Windows XP or newer
• Your nuvi 30, 40, or 50 device
• mini USB cable to connect your device to your computer
• Access to your vehicle and power cable once you have completed the recovery process
Update your Software
1. Download and install the Garmin USB Drivers
2. Download the Recovery Application and corresponding recovery file for your device, and save them some place easily found, like your Desktop:
o nuvi 30 Files:
nuvi 30 recovery file
o nuvi 40 and nuvi 50 Files:
nuvi 40 and nuvi 50 recovery file
3. Drag and drop the .rgn file on top of the Updater.exe Recovery Application. The application will launch.
4. With your device disconnected and turned off, use your thumb to apply pressure to the upper-left hand corner of the touchscreen.
5. While still holding the touchscreen, connect the device to your computer using the mini USB cable.
6. The Updater program will detect your device and will list the device in the "USB Device" drop-down menu.
7. Click OK and let go of the touchscreen
8. Your nuvi will now go through the process of updating software. It may power off and on during this process. Once complete, your device may display the following message:
The software on the device is newer than the software you are attempting to install. Installing the older software will erase all user data. Install the older Software?
If this message appears, please select No.
9. Disconnect your device from the computer and connect it to your vehicle power cable while plugged into a live power outlet in your vehicle.
Your device should now be recovered and updated.
Still having problems?
Customers living in the United States or the United Kingdom can follow the steps below to automatically set up a repair for your product. Customers living elsewhere can Contact Us for further assistance.
1. Visit the Garmin Repair Center
2. Click 'Go' to enter your device Serial Number
3. Enter your Serial Number twice in the pop-up menu
4. Confirm your model number and Click on your device
5. Select "Power or Battery" as the Problem Category
6. Select "Locks Up, Freezes or Turns Off Unexpectedly" as the Problem Subcategory
7. Select "Frozen on Start Screen"
8. Enter additional notes describing your problem
9. Click Continue
10. Click "Yes" to submit a request for a repair or replacement?
11. Sign in to your myGarmin Account
12. Confirm your shipping address and e-mail, click submit
You will receive an e-mail within 10-15 minutes after completing this process. Please follow the instructions in that e-mail to complete your RMA.
Apr 25, 2012 | Garmin GPS
My garmin nuvi 250w wont turn on
Try this: Slide and HOLD the power switch into the ON position for 10 seconds or until it turns on - which ever happens first. This forces a reset / reboot of the GPS. It does NOT delete any data.
If that doesn't work, the battery may be discharged. Recharge by connecting to your computer's USB port with a USB cable, or with the AC adapter (if yours came with one) for 8 hours. Do not use your car's cigar lighter or power point to do this (it won't work). Turn on as normal or failing that, use the slide & hold method detailed above. After starting up with the slide & hold method successfully, subsequent power up operation can be done in the normal manner. You can use the slide & hold method any time the GPS fails to start up normally.
One power up method or the other should allow the GPS to start if the battery still has a useful life. If it does not power up, it is likely that the battery is no longer capable of holding a charge. In this case, you may purchase a battery and attempt to replace it yourself (this is a fairly involved process), or you can contact Garmin Tech Support to arrange for a flat-rate repair.
I hope this helps & good luck!
Feb 28, 2012 | Garmin nuvi 250W GPS Receiver
My nuvi 1450 won't turn on and the garmin website updater won't reconize it hooked up to my computer even my computer won't reconize it.
I had the same problem with mine and got it working by doing the following while on the phone to Garmin. Plug your charger cord into the device and your computer (do not use a laptop, you need the higher current from a desktop for this). Hold the power button down for as long as it takes for the Garmin logo to display, this could be as much as 1 minute. As soon as the image shows on the screen, release the power button. If your Garmin isn't completely shot you will see it boot up.
If you have the Garmin Web Updater program on your computer, run it and update the operating system software to insure you have the latest greatest from Garmin. Once that is done, update your XML data files - they'll be on the list of updates if you need them. Once those are done you can update any voice or language files you'd like.
Lastly, leave your GPS plugged in at least an hour or two to give it a charge. Overnight would be better to insure your battery is really well powered up.
At this point your Garmin should function normally. The Garmin tech I spoke with told me some units start acting funky when the battery runs down too low and if it's REALLY dead it won't even take a charge or power up when you hook up your charger cord. Try holding the power button for as long as it takes to get a spark & you should be on your way. If not, call Garmin's support number for your locale & they're do their best to get you back up & running again.
Cheers, Jeff
Sep 01, 2011 | Garmin nuvi 1450 GPS Receiver
I have Garmin Nuvi 265W. When I plug my car charge to charge up the battery and use the Navi at the same time, I only get the "GARMIN" screen connected the computer but can't use Navi function...
Try a hard reset,the Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  3. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  4. Press "yes" and the unit will reboot. This resets all your location settings and user preferences
Then make sure the unit is fully charged,then go to the Garmin site and register your product. Then download Garmin Updater and connect your unit with a usb cable directly to your computer and not thru a USB hub. Let the update go directly to the GPS and not a folder. It will take a few hours even with a fast internet connection. I have attached a link to the Garmin site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 01, 2011 | Garmin Nuvi 265W GPS Receiver
Nuvi 215 does not boot. As soon as the Garmin logo appears it reboots itself and continues in an indefinite loop
FIRST, be certain you have a fully charged battery.
Then try doing a master reset:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to perform a master reset on your nuvi 200, 205, 465, 500, 600, 700, 705 or 1000 series device?
To perform a Master Reset
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Jan 17, 2010 | Garmin nuvi 215 GPS Receiver
Is m Garmin nuvi 200 GPS charging
Merritt, Your Garmin Nuvi does not have a charging indicator similar to say your Cell ph. Simply a battery charge indicator scale. Normal full charge time is approximately 3 to 4 hr. If you looking to ensure your unit is in fact charging Plug in & then remove the connection, Your unit will pop-up a screen to request if you wish to remain on battery power. I hope this helps you.
Mar 09, 2009 | Garmin nuvi 200W GPS
Garmin Nuvi 660 shutting off
It sounds like your battery is defective. They can be replaced. The Motorola phone cable is not wired exactly like the Garmin, and your Nuvi thinks it's connected to a PC. Radio Shack carries a charger for the Nuvi. I have one myself.
Let me know if you need additional help with your battery problem.
- Jim
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 40 Logo
382 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
