Question about Insignia IS-LCDTV32 32 in. Television
Insignia ns-lcd32 no video
Insignia ns-lcd32 has audio but no video. Purchased august 2007, not covered under waranty. Tried backlight test with flashlight but still no picture. Would like to replace failing module if it can be identifed, looks like only two video modules inside tv. Any information is gretaly appreciated.
  • martb May 18, 2009
    I have exactly the same problem. Suddenly, Insignia ns-lcd32 has audio but no video. Tried to connect it to my laptop, and it recognizes it as an external screen, but still no picture. Any solution?
5 Suggested Answers
SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
Posted on Apr 01, 2008
  • 61 Answers
SOURCE: Same Insignia problem but still not working
Check if there is back light on or not?
If back light is on means this unit is having problem with panel (deffective.).
If there is no back light change main baord.
Good luck
Dals123
Posted on Oct 10, 2008
  • 61 Answers
SOURCE: INsignia ns-lcd32
Yes..Do you have the part number?
  • 61 Answers
SOURCE: insignia ns-lcd32
Bubulica2000,
There is two reasons to have no display on your screen.
1.LCD panel itself is deffective.
2.Main board(mother board is Deffective)
How to recoganize the problem?
There is 5VDC going from main board to LCD invertor ( different model different pin so I am not able to tell which pin or Jack is)
Check while unit is ON mode it should read in between 3VDC to 5 VDC.If this volt is correct your LCD panel is Deffective.If no voltage appear in this pin Simply change Main board(mother board)
Dont forget to rate!!
GoodLuck
Dals123
Posted on Oct 21, 2008
  • 11 Answers
You can download the manuals from the Insignia website at:
http://www.insignia-products.com/c-14-lcd-televisions.aspx
Jerry
Posted on Dec 08, 2008
Where is the location of T CON board on NS LCD32
Cheryl, I will post links to what the T con board looks like so when you remove the rear panel from TV, you will be able to compare and find it easily.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
INSIGNIA NS LCD32 Con Board LC320W01 SLA1 6870C 0142B 2L
Amazon com INSIGNIA NS LCD32 CON BOARD CPT 320WF01C SD Electronics
Mar 23, 2016 | Insignia NS-LCD32 LCD TV
Insignia ns-lcd32 has developed a vertical shadow.
Unfortuntly you have a panel that is going out. This is not cost effective to fix.
Apr 11, 2012 | Insignia NS-LCD32 LCD TV
Insignia NS-LCD32
Most likely either the main board (processes all signal) or even an issue with the power board (supplies wrong voltage somewhere).
In either case not cheap.
Mar 23, 2012 | Insignia NS-LCD32 LCD TV
Purchased model NS-LCD32 second hand with no
Since you are getting the signal from the satellite, leave the satellite receiver ON and press input on the TV buttons until you get the signal back, wait 2 seconds after pressing the input button. Make sure the TV is on channel 3 if you are using the antenna input.
Let me know if you need further assistance.
Jun 13, 2009 | Insignia IS-LCDTV32 32 in. Television
My Insignia NS-LCD32 TV won't power on. The remote has good batteries, the outlet has power etc. Insignia says to unplug it it for a few seconds and then plug it back in. I tried that multiple times w
The power surges have probably blown the fuse in the power supply board. This may not be the only problem.If you are still under warranty, you will need to have it serviced at a service center. If not You will need to find a repair person or center to open the unit and test it for you. This television and all your electronic equipment should be protected with surge protectors. The reason is your power company has problem with power outages and this will damage your equipment. There is no built in self defense for this equipment due to the huge variants involved with power companies. You should call Insignia and ask them where you can find a authorized service center. You can call the Insignia customer support at this telephone number 1-877-467-4289. Tell them the model number of your television and the problem you have had with its failure to turn on.They will be able to help you find a service center to test and repair your television. I hope this information helps you with your problem.
Jun 03, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia ns-lcd32-09 wont play VHS
Yes, that is correct you need composite (or coax) cabling to your TV. The unit cannot carry the VHS signal via component video or digital audio cabling
Feb 27, 2009 | Insignia IS-LCDTV32 32 in. Television
I have the following tv, Insignia 32" Flat-Panel LCD HDTV** (NS-LCD32-09CA) I get audio sound but no video output
Power supply board most likely, I have one just like it with the same problem in my shop right now.
Dec 26, 2008 | Insignia IS-LCDTV32 32 in. Television
INsignia ns-lcd32
Oct 10, 2008 | Insignia IS-LCDTV32 32 in. Television
Mar 01, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
166 people viewed this question
Top Insignia Televison & Video Experts
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
