Question about Keurig B145 OfficePRO Brewing System
B145 is not dispensing water though the light is flashing that it is ready. It is making the noise like it is going to pour but nothing happens
  • 60 Answers
SOURCE: The Keurig is heating up the water, yet is does
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
Posted on Mar 23, 2010
heatman101
  • 43501 Answers
SOURCE: Our Keurig machine says "ready
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
ftw1952
  • 10319 Answers
SOURCE: We have model b80 that will not brew. Water
add a cup of distilled vinegar and let stand overnight then try it in the morning to descale
Posted on Jun 05, 2011
heatman101
  • 43501 Answers
SOURCE: When I push the "brew" button, it makes noise like
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: When I press brew, nothing
heatman101
Posted on Sep 04, 2011
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
My machine blinking on steam, the wand does not want t o steam, the espresso does not pour. The knob is turned on stand by , but still some steaming noise comes, but no steam comes from the wand, nor...
When it is blinking on steam it means it is preparing the unit for steam. When the steam light goes solid your unit is ready to make steam.
  • Turn from standby to steam then wait for steam light to go solid.
  • When solid steam wand will begin dribbling then spitting out water, which will then turn to steam.
  • When it begins to steam, turn back to standby. NOTE: you only have 6 seconds before steaming turns off.
  • place steaming wand in jug and turn from standby back to steam.
You will hear pumping noises when you turn off your steam, because it releases the steam and puts the excess water in to the drip tray.
  • make sure your bean hopper is properly locked in to the unit. Grinder won't work if hopper not locked in.
  • Make sure your water filter has been prepped and locked securely in to the reservoir and your reservoir is filled.
  • Use fresh beans.
  • Sounds funny but use good quality water, do not use ordinary tap water. Make sure it is filtered or use bottled water (cooler bottles).
  • Try to grind your beans to a good consistancy.
  • Breville recomends about 10kg tamping pressure, use a set of scales to check the feel.
  • Tamp to about 3-5 mm below rim of grouphead (portafilter). Or the tamp has a guide on the side, that silver side on the tamp is the tamp line. Pretty vauge about that in the book.
If all else fails go to www.breville.com.au and check your model and watch some of the vid clips.
Jan 06, 2011 | Breville Fresca BES860 2Cup Coffee Maker
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
Mar 18, 2010 | Whirlpool GS6NVEXSL Side by Side...
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
GE Side by Side Refrigerator dispenses ice but no water
if the light is not coming on i would say that board needs replaced and it just pops right out
Mar 16, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser light flashing and no water at first
sounds like you've got power problems -- either there's an wiring issue somewhere or you've got a bad board
Dec 13, 2007 | Hotpoint HSS25GFP Side by Side...
Flashing water light - will drain water but will not make coffee
Something is wrong on the coffee cycle side of the machine. Check the brew unit screens and and try doing a preground cycle with out inserting coffee. IF water comes out, I would looking into your grinder a little bit and try increasing the grinder size.
Espresso parts and service
www.cerinicoffee.com
Dec 08, 2007 | Saeco Magic De Luxe Espresso Machine
Keurig B145 OfficePRO Brewing System Logo
47 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
