Question about Epson Stylus Pro 9880 44" Printer Colorburst Edition
Black spatter on prints
After cleaning i can still get black spatter on my fine art paper prints. sometimes three or four prints in a row. ive removed the back and cleaned the wiper blade and the gasket on the pump cap(?)... then cleaned the ramps on the print head and the print itself (surface). Both my 9880s are about for years old or more and the other one can have a subtle banding problem that begins 2/3 of the way across the print. Ive done the print head adjust and it can still happen even with a good nozzle check. Are they just pat their useful life? thanks, mike
jay196969
  • 41 Answers
SOURCE: horizontal banding
have you tryed to update your drivers on the printer
Posted on Dec 15, 2007
SOURCE: Cannon Pixma skips when it prints black
hmmm..can you do a test page to see if it's also the case?
http://tinyurl.com/6qcpgy
Posted on Aug 19, 2008
SOURCE: everything is coming out pink
one of your ink cartridges is low. Annoying I know, since its not empty, but happens a lot.
Posted on Dec 16, 2008
  • 68 Answers
SOURCE: Not printing
You probably have paper debris stuck to the underside of the print head.
While you are printing, pull the lead from the back of the printer leaving the head free floating and unlocked so you can slide it back & fore. Get a piece of kitchen roll and fold it until it's the size of the track beneath the print head slide the head to the left, place the folded kitchen roll flat down in the print track, slide the head over the folded kitchen roll until it appears on both sides of the head. Grab both ends of the roll and lift it toward the head. Slide the roll sideways left and right to physically clean the bottom of the print head. Try not to tear it as it will trap under the head. let go of one end and slide the head away until you can pull the roll out. It should have a lot of ink and gunk on it. Plug the printer in and the head will reset itself.
Now because printing has been non existant, you'll need to "Prime" the heads. Use the maintenance software and click head cleaning, when finished do not allow the nozzle check pattern to print. Carry out 3 more head cleans cancelling the nozzle check after each one by clicking [Finish] until 4 cleans have been completed. Then allow the nozzle check pattern to print and it should be back to normal. If not perfect, carry out another "Prime" as above.
Hope this helped.
Nigel
The INK Store
http://www.the-inkstore.co.uk
Posted on Jan 17, 2009
gwbm
  • 353 Answers
SOURCE: Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Posted on Feb 01, 2009
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
BLACK CARTRIDGE PRINTS IN SPASMS BUT COLOUR CARTRIDGE PRINTS FINE.
I didn't get your question,even I am trying to give you solution. Switch on the printer, left top cover wait until carriage arrive at middle, remove mono cartridge, take out swab nozzle area with good cotton or ear buds adding with alcohol(solvent) gently in one direction,repeat three to four times & shake well and see ink coming out from nozzle area?, clean nozzle area with tissue paper put it back & check for print..
Feb 04, 2012 | HP DeskJet 5150 InkJet Printer
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
I have a HP LaserJet 5P. This has been a great printer with excellent print quality. Recently I printed a file that had a lot of dark background. Since then the printer output has a spattered black...
Geez, a real oldie.
If you pull down the back door, I think that you can see the fuser.
It's been a long time, but let's see how this goes. The back of the fuser, I think pulls down.
If it does, look at the rollers inside. There are two of them. Do they look dirty or torn?
If yes, you need a fuser.
Run a 1/2 print test. Send a print job to the printer. It has to be about 4 pages. Use the manual feed tray, so that you can watch. When the sheet of paper gets 3/4 of the way in, open the top cover. Pull out the toner and look down at the paper. Does it have the black splatter?
If yes, replace the toner cartridge. If no, replace the fuser.
Jan 15, 2011 | HP Office Equipment & Supplies
Black prints 1" either side of page. middle fades to nothing.
clean the paper path rollers. usually if toner cartridges are refilled type they are overfull and spill toner on paper path.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Ricoh Aficio CL3500N Laser Printer
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
I have a hp deskjet 5150 which printed fine until yesterday (Oct. 13). Now I get a “black print cartridge isn't compatible with this printer” message, which, of course, is not true. I also have a blinking...
My first thought would be to remove the black ink cart. and clean the connectors with a Q-tip and alcohol (water will work in a pinch). Sometimes ink will spatter up into this area and cause problems. It is possible that the cart. has a malfunction also - but not likely.
Oct 14, 2008 | HP Office Equipment & Supplies
Black ink
Print nozzles will be at bottom of cartridge...Make sure that u do not wet copper contacts ... first try using dry paper towel and check where ink comes and follow the procedure given below....
Cleaning procedure
  1. Remove the print cartridges.
  2. Moisten a clean, lint-free cloth with water.
  3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown below.
  4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
  5. With another clean section of the cloth, repeat steps 2 through 4 above.
  6. Allow the nozzles and contacts to dry completely.
  7. Reinsert the print cartridges.
  8. Print the document again.
  9. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
  10. Check the warranty and try to get replaced
Jan 18, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Smudge marks on paper; otherwise normal
fuser is usually replaced as a assembly, it's the hot bit a back.
Can only be two things the drum or the fuser as our headstrong friend has correctly explained.
More than likely it is the drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine
Jan 07, 2008 | Brother HL-2040 Laser Printer
Epson Stylus Pro 9880 44" Printer Colorburst Edition Logo
77 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
