Question about Water Heaters
Where is the non return valve on a truma c343 water heater
None return valve
2 Suggested Answers
  • 70 Answers
SOURCE: Carver cascade 2 No water at all comes out of the
Check the tank drain valve for water there.If you get a good water flow there you know the tank is getting water pressure.Check the first outlet downline from WH and if there is no water there you have a blockage or other problem.If you have to turn off water to tank, remove the outlet pipe ,and check for water flow from tank with in valve on.If no flow, tank is plugged up.
Hope this gets you going.
Posted on Oct 06, 2009
Testimonial: "Confirmed my diagnosis. Any idea how to get it unblocked?"
Truma Ultra store water heater. How ti hard wire from 230volts. Many Thanks awaiting reply ?
There may be a wiring diagram pasted somewhere on the heater. If not, request the diagram directly from Truma.
Aug 27, 2017 | Water Water Heaters
Water system problems
- normally water tanks are mains fed so the auto shut valve for the water tank could be faulty but more often than not, it will overflow the tank through natural wear of the washer. the auto shut valve is normally some kind of ball **** valve.
Aug 22, 2016 | Water Water Heaters
Truma c 3402 water boiler
Sounds like a bad Relay on the control board
Mar 17, 2016 | Water Water Heaters
Truma water heater water wont come out of the taps when on gas, 12 volt or mains 240 volt
Bleed your propane system by running the stove for a sec. if that doesn't work go out to the heater and listen for the ignitor clicks see if it's trying to lite. My fifth wheel does this first time every season.
Feb 22, 2015 | Water Water Heaters
Non return isolating valve dripping water tinuously
you have trash in the valve .shut it down take the valve apart clean it . also maintenance on this unit is needed.seal can be bad also. hope it helps.send pictures of the unit and age and model serial number.
Apr 06, 2014 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Hot water is flowing from the water heater into
boiler type? Combi,standard,if your boiler is a combi the non return valve onto your heating line may be defective thus hot water slippng back through cold line best of luck
Oct 27, 2009 | Water Heaters
Electric water heater will not stay on
sounds like the electrical thermostat is defective and is being over ridden by the overheat safety stat.
Nov 17, 2008 | Water Heaters
Water Heaters Logo
77 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
