Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover Steam Vac leaks like a sieve
When i try to use my hand tool on my steam vac there is a huge puddle of water under the vac where it has leaked how do i fix that??
Others on this forum have indicated the same problem - but no solutions - can anyone help??
  • 2 more comments
  • jtinnire Jan 13, 2009
    I have the same problem when I try to use my attachment. There is lots of water leaking out the bottom.
  • eternaljewel Mar 05, 2009
    I just tried mine and its doing the same thing.. Also I can't get the floor brushes to stop spinning even in the off position. My model is F5915-950
  • Anonymous Mar 11, 2009
    my husband and i took the whole thing apart 4 different times and could not find the problem.
  • April D Jackson Aug 03, 2013
    I also have the same problem. Only solution I came up with was to buy a plastic storage tub that was big enough for me to set the machine inside when i was using the hand attachment, to catch the water that was leaking
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Posted on Aug 31, 2009
  • Louis Spaner May 05, 2013
    While that fix did indeed stop the leaking, it also prevented the hand attachment from spraying the cleaning solution...did anyone else find this to be the case?
I just had this same problem (with my girlfriends fathers hoover, no less!) I had the cleaner on a tile floor trying to use the hand attachment on the sofa, and I noticed the puddle. When I put the cleaner on a carpet, it seemed to work fine. Not sure if it wasn't creating a "vaccuum" on the tile or what, but it seemed to remedy it. Also, make sure the hose it attached securely at the base.
Posted on Mar 30, 2009
  • 107 Answers
Are you hooking up the water atttachment for the hose. If not try that should hook up on the right side. If this model does not have that option or you do have that hooked up then it is the solenoid which you can get through Sears parts direct
Posted on Jan 05, 2009
Model 5835-900 leaks when using the hand tool
Take the 4 screws that hold the hood out and remove the hood. Hook up the hand tool line and watch for where the water comes out. It is more than likely the tool valve has failed.
This is the part here:
http://vacuummedic.com/product.php?id=231
Good Luck!
The Vac Dr.
Dec 20, 2012 | Hoover F5835900 Upright Steam Vacuum
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
Jul 28, 2012 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac leak from the bottom when tank has water in it when not running but tank is not leaking
The tank is not sealing to the black rubber ring seal on the lower handle. make sure this seal is not displaced.
Nov 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Water tank leaks
If the tank is leaking, when removed from the cleaner, it is not user serviceable.
Oct 01, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac clean water reservoir leaking.
take the clean water tank out and look on the bottom for a fitting that screws on make sure its tight.also inside of that fitting trhere should be a washer or an oring to keep it from leaking.if thats not the problem then your pump mightbe leaking.for that i would take it to a vacuum repairman.i hope i have been of some help.please leave feedback
Apr 07, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Steam carpt cleaner
If water is leaking out the bottm, remove the top housing, and look for a water line that has come off or is cracked.
Jul 13, 2008 | Vacuums
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
6,769 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
