Question about Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)
Thermocouple glo warm mod 28000ng need replacement
Need a replacement thermocouple for a glo warm heater model fas28000ng
  • 4 Answers
SOURCE: heater will not stay lit
yes for sure it's the thermocouple
Posted on Feb 05, 2009
SOURCE: Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Posted on Feb 24, 2009
  • 128 Answers
SOURCE: i have a 5 year old glo-warm ventless
Since the thermocouple body is made of metal, and often these have a copper or brass sleeve, that *should* provide good grounding for the thermocouple.
Obviously some engineer at the heater company did not agree with this, so he added an extra ground wire.
Most gas valves are not all that sensitive to exactly how many microvolts the thermocouple feeds to it.
My guess would be that if there is a cheap metal bracket that holds the thermocouple, such as unplated steel or tin, the extra ground wire counteracts the effects of corrosion over time.
So if the heater were stored in a damp garage, the thermocouple connection would get corroded, and the heater would not stay lit. The fix is the extra ground wire.
There are two types of failures with thermocouples: the safe-failure is when the gas is shut-off, even when flame is present, and the unsafe failure would be when gas is not shut off, even when no flame is present.
If the thermocouple somehow was not adequately grounded, then the most likely failure would be a 'safe failure' , such that the burner would not stay lit.
You could rig up some sort of extra grounding wire, but unless the part is subject to extreme vibration or is in an extreme (wet/salty) environment, it's probably not needed.
Of course, to be safe, do a flame blow-out test after you install the new part. While it's highly unlikely that an unsafe failure could occur, better safe than sorry.
Posted on Oct 21, 2009
  • 3310 Answers
SOURCE: warm glo- GWN10-thermocouple
Try national energy they are on the wed or on the phone book they stock most parts or ry rinnia parts online , no you will not be able to solded a wire to it
Posted on Feb 17, 2010
  • 4736 Answers
SOURCE: i need a thermocouple for
Billy here's a link to A & B Sales. They have what you're looking for. Whether your heater is Natural Gas or Propane makes no difference when it comes to thermocouples.However the length of the tubing does when it's a wall or stand type vent-free heater.
http://www.aandbsales.com/2.html
Hope this helps you & thanks for choosing FixYa.
Posted on Sep 21, 2011
WHAT SIZE PROPANE TANK DOES THE GLO WARM 630 NEED?
The tank size dosn't matter all you need is a feed line This looks like a spicific tank appalaction but just feed it remotely with a normal propane tank and a feed line and save your self the head ache as long as it dose what you want it to do ist cool
Mar 06, 2012 | Mr. Heater Thermocouple
My natural gas glo warm gwn6 wall heater keeps shutting off
Julie, the problem you're having with your DESA, Gas Glo Warm heater may be the result of a clogged Oxygen Depletion Sensor (ODS) which is part of the pilot. I have included a link on how to clean the pilot and the ODS, as well as the burner, that you can download and print for future reference.
http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
In addition, the thermocouple may be failing and will need to be replaced. To troubleshoot this, here is another link that will help you. http://www.desatech.com/techDocs/Thermocouple%20Troubleshooting.pdf
If after doing all of the above and you fin it's necessary to replace the Thermocouple, You can purchase one from A & B Sales
Sep 23, 2011 | Heating & Cooling
I need a thermocouple for a dyna glo heater model #RMC-40GT
I believe on your particular model , that you have to replace the entire pilot assembly. As the thermocouple is an intricate part of it. In which case any LP or Natural Gas heater's pilot assembly will fit it. You will have to secify either Natural Gas or LP Gas when ordering.
I have provided 2 links to where you can purchase the pilot assembly you need.
http://www.mrheater.com/OrderParts2.aspx?catid=57
http://www.aandbsales.com/index.html
I hope this helps you & thanks for choosing FixYa.
Jul 29, 2011 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
How and where do I replace a thermocouple on a warm glo wall furnace? Help
There should be a thermocouple in front of the burners that has a copper colored wire that runs from the gas valve to the thermocouple. It is located in the pilot flame as it is a pilot proving switch that tells the gas valve the pilot is lit and its okay to open the gas valve to the main burner.
Mar 21, 2010 | Desa International Blower Glow Warm Wall...
Glo-Warm Model #WMN20 20,000btu. Can hold down and ignite the pilot but as soon as i let go the pilot goes out and with out igniting the unit.
WITH THE HEATER OFF, clean the pilot flame unit with a can of compressed air. Blow directly into flame hole then try it again. if it continues to "not" stay lit then you need a new thermocouple.
Oct 27, 2009 | Desa International Blower Glow Warm Wall...
Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Nov 03, 2008 | Desa International Blower Glow Warm Wall...
Thermocouple replacement parts
sorry..seems parts for your model are no longer carried by anyone i can locate. but.. i did find that MR HEATER bought up some of the DYNA GLO product lines. you could call them...800-251-0001 talk to tech support.
or..call AMERICANHVAC.. 866-432-8551. they may be able to cross reference the part for you. sorry not much help.
Sep 17, 2008 | Dyna-Glo Heating & Cooling
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
100 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
