Printer won't print. get message, " The print carraige is stalled". It moves back and forth with ease, so what might be my problem. It just started yesterday and I'm lost.
  • Joe Neff May 11, 2010
    What kind of printer is it model# and age.......Joe
  • 685 Answers
Try taking out the ink cartridges and putting them back in
Posted on Jan 04, 2009
Turn the printer off and unplug it. Open the area where the catridges are. Gently move the carriage back and forth to make sure it is free and able to move. If it is. Plug it back in and turn it on and it will re align the carriage itself. If you cannot move it or the tape that holds it is trapped or broken, then you will need to send it to an hp repair facility.
Mar 08, 2011 | HP DeskJet 3930 InkJet Printer
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
Every time I send a document to print, I get the message, "Paper Mismatch. Paper detected does not match paper size of type selected. Change paper and press OK on the hp officejet to continue...
When you print the document then select the size of the paper you want that to be print in. It will ask you when you print the document. It might be the case the default A4 size is set to other.
Try it might it can help you out.If not leave a comment will provide another solution.
Oct 11, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I changed my ink cartridges (x2600)and now when i try and print i get a cartridge stall message. Also the letters J and E flash seperatly where the number of pages would appear. I tried taking the ink...
I had the same problem. E J kept flashing. My black cartidge on the left side wasn't set correctly. It was a refill from a store an was smaller and looked different than the color . It was blocking the ink carraige from moving. I took out the black and pushed it back as far as possible. Now it works fine. Hope it works
Aug 31, 2010 | Lexmark X2600 InkJet Printer
Printer Carrier Stall
You may have had a foriegn object fall inside the printer such as a pen or paper clip.You may also have a broken sensor which enables the carraige to move to the centre when the lid is open. You can try and carefully move the carraige over manually when the printer is turned off to see if there is something blocking its path. If the sensor is broken you can replace the cartridges by moving the carraige over when turned off.
May 28, 2010 | Dell 922 All-In-One InkJet Printer
Power led blinks - canon pixma pro9000
Your canon printer needs to be serviced. That error is treated with special lubricant applied to a cam assembly inside and above the sheet feed assembly.
Mar 22, 2009 | Canon Office Equipment & Supplies
Noisy hp7450 printer
There's a rubber part in the printer on the right inside the printer underneath the print carriage that slides back and forth. If this has moved it will foul the print head. I moved mine back into the right place and the print head now moves freely.
Hope this helps,
Nov 05, 2008 | HP Photosmart 7450 InkJet Printer
Printer Cartridge Carriage Stalls
the settings of the gears is misalligned.a technician at your place is advisable as this is a very important part of the printer if any of the arm breaks the printer may face major problems.still stick that arm with a cellow tape on it firmly and then give a print out.if the page prints properly that means it got adjusted automatically.
Oct 18, 2008 | HP PSC 1610 All-In-One InkJet Printer
Carraige Jam
maker sure the cleanout station is not moves also...dont break it just see if it isn stuck...move the carriage back and forth. put paper in it and turn it back on.....if that does not work..take the paper out the back and roll th big wheels a bit and try again.
Oct 13, 2007 | HP WanProbe V-Series Network Monitoring...
125 people viewed this question
