Question about HP OfficeJet 6210 All-In-One InkJet Printer
Carriage Jam Everytime we print the printing carriage gets hung up and we get the carrage jam error message. there is nothing that the carrigae is getting caught up on- Please help-- we have re-installed the ink carriages- turned the printer on and off
  • Jen73 Jan 08, 2009
    I have had the same problem with my HP officejet 6210. I had it looked at by a friend and they found a huge lump of dried ink under the ink cartridges. When that was removed the printer worked fine. That may or may not be your problem as well.
  • adwhite Jan 11, 2009
    hp 6210, paper jam error, but there is no jam. carriage slams back and forth then gives the paper jam error. i tried the # and 3 reset and it didn't work. I also cleaned the guide strip and that didn't work. the carriage just slams to the right and left.
    Genius:
  • 1,605 Answers
If either a paper jam or blocked carriage error message appears on
the control panel display, there might be some packing material inside the HP allin-
one. Lift open the print-carriage access door. The orange shipping lock might
still be in place on the left side of the HP all-in-one. Pull out the orange shipping
lock and throw it away
Posted on Jan 08, 2009
Someone gave me this printer and I just purchased ink for it. Unfortunately all it does is give me error messages. The first message is the I need to turn it off correctly by using the On button. I have...
actually there is a carrage jam problem in you printer.switch off your priner .remove the power card and try to move the carrage block to the other end and try
Aug 02, 2011 | Office Equipment & Supplies
My printer quit printing. Carrag jam comes up on the screen when I try to print something out. There isn't anything jamming it. What can I do to fix it
Issue:
A 'Carriage Jam ' error message displays on the product control panel. The carriage, which holds the cartridges, stalls against the left side of the product. A paper jam might have occurred previously.
Detailed instructions fro resolving a carriage jam along with a video are available here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01309787&cc=us&lc=en&dlc=en&product=3418705&tmp_track_link=ot_search
Trust this is helpful. :)
Dec 08, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Aug 21, 2010 | HP PSC 1610 All-In-One InkJet Printer
Carriage jam - Turn machine on, get carriage jam message, however the carriage can move freely if moved by hand. If I close and hit enter, carriage sounds like it's moving, then I get the error message...
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Jan 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Carriage jammed
first open the door and ckeck out any optical in carrage moving area are not shigted if the carrage movoing area are free then ckeck in service station it is working properly or not if it is working properly then ckeck the endcoder strip and if it is also ok then reinstalled the mecanism your problem will be solved
Jul 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
Carriage Jam Error from replacing refilled cartridge
Cleaned the roller & carriage assembly, If possible service the printer your printer will work fine.
Mar 10, 2008 | HP PSC 750 All-In-One InkJet Printer
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Carriage jam
My wife had replaced bith ink cartridges and the carriage was also jammed! what she did was helped the cartridge carrier up some and it finally clicked in!!
Jan 23, 2008 | HP PSC 1610v All-in-One Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
238 people viewed this question
Ben Johnson
