Question about Bissell 3522 PowerForce Bagged Upright Vacuum
My vacuum puts out stinky air
I tried finding all of the filters to clean them and all I've found is two. Is there more? I've cleaned out the hose and changed the bag. Is there any where else I can clean to get some better smelling air as I vacuum?
    New Friend:
  • 3 Answers
In residential cleaning we use vacuum for removing dust from carpets. The speed air flow helps to remove sticky dust, if you want to hire our service, you contact us http://www.servicemaster-mb.com/house-cleaning.html
Posted on Jun 01, 2016
We put small moth balls in our bag when we change it.
Posted on Jan 27, 2009
Riccar 8995 no suction in hose
drop a quater thru hose make sure it goes thru
May 18, 2014 | Riccar Vacuums
Miele Silver Moon Losing Suction Power
That is possible, also check for a.m. exhaust filter off the motor. Usually a very fine filter to stop dust that gets past the bag. May just need to open it up and clean out the accumulated debris.
May 02, 2013 | Miele s558 Silver Moon Vacuum
Dirt Devil Ultra Vision vacuum- no suction?
Check for a clog at the neck of the "bag".
Sep 11, 2017 | Dirt Devil Vacuums
Can anyone help with an older Euro Pro EP055, It has very little suction.
Cleaning filters on a bagless vacuum helps but filters should be replaced frequently, as often as every 3 to 6 months on some vacuums. Foam filters aren't as critical to replace because the pores are very large (which also means they don't filter out the small particles) so they don't clog as easily but paper filters have much tighter pores which become clogged and restrict the airflow. Cleaning paper style filters with water which can pack the fine dust into the pores clogging the airflow even more.
I recommend replacing filters st least onceor twice per year and cleaning them after each use for best performance and longer vacuum life. Blowing the dust out with an air compressor is my preferred method.
Changing filters frequently on a bagged vacuum isn't as critical because the bag collects most of the fine dust, dirt and gunk. The surface area of a bag is much greater than that of a filter so a bag is less likely to get clogged than a filter. Most homeowners change the bag once per month which keeps the air flowing smoothly.
Sep 30, 2017 | Euro-Pro EP055 Bagged Canister Vacuum
Loss of suction o=with hose tool
Hose or tool is probably clogged. Is this an upright? Bagged or bagless? Have you changed the bag and filters? Cleaned out the brush and hose that goes from the brush area to the collection bag/cup? The only reason for a vacuum cleaner to lose suction but still work is a clog or dirty filter which blocks the air flow. Follow the air flow from the brushes to the bag/dirt cup. If the machine is bagged, change the bag. I use another vacuum cleaner to do this.While your at it, might as well change the belt.
Nov 15, 2011 | Hoover Vacuums
My dirt deivl want pick up dirt that well. what is the promblem?
Most likely, it needs to be cleaned out. Change the bag (or clean the dirty cup), change or clean all filters and hoses . Clean the brushes. It probably sucked up some water and combined with dirt it clogs up filters and hoses.
Oct 18, 2011 | Vacuums
Hi there Our vacuum cleaner exerts no pressur and it doesnt **** anything from mat,, it is just 4 months old bt we have missed the receipt,, cadsn u please help us? thanks and regar
Check your filter/bag especially if you've used it to clean fine particles; they will tend to clog the filters or bag and cause loss of performance. It the filters/bag are good and/or new, check for an obstruction in the hose or suction tube.
Jun 30, 2011 | Vacuums
Vacuum just stopped working.
is there a filter in it if so clean the filter.try it without the bag in it.make sure the bag is in correctly.does the bag expand when you turn it on.you might have something caught up in the hose.take the hose off and blow througfh it.if you can't its clogged.also check the inlet where the dirt goes into the bag.the inlet might be clogged.please leave feedback
May 04, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
Jan 26, 2009 | Kenmore Vacuums
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
198 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
