Question about GE Cafe CGS990SETSS 30" Free-Standing Gas Double Oven With
What is a choke and screw for ge cafe gas stove
3 Suggested Answers
mgprice
  • 744 Answers
SOURCE: ge gas stove top keeps clicking
Hello, your problem is going to be 1 of 2 problems, 1st did you spill liquid on the switch? if so the switch has shorted out, unplug the appliance for 24 hours to dry the switch out then plug it back in...if after 24 hours it is still clicking you have a bad switch (these are the burner knobs) check each one with a ohms meter, the one that is bad will read infinate on your ohms meter when it is switched off. If you have any other questions please feel free to comment. Good Luck!! Mike
Posted on Sep 22, 2009
Testimonial: "yes, liquid was spilled into the burner, thanks for the advice will give it a shot.."
sonicboomele
  • 1557 Answers
SOURCE: Hi I have a GE cafe brand gas stove and decided to
always use a non abrasive cleaner solution. so there are no streaks in future. as for now with the brown build up in the workshop we use oven cleaner mr muscle it will lift the grime and not harm the surface. its a little known trade secret
(dont tell anyone else) ;)
merry christmas
please take the time to rank this advice below
Posted on Dec 22, 2010
My GE Cafe microwave touch pad will not work. Everything seems to be working. It is a built in , above the stove 2008 model.
Here is the information page on the repair of GE Cafe microwave ovens.
http://www.microwavecontrol.com/jvm2070.htm
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | GE Microwave Ovens
Ge cafe stove bottom oven not working
Is there 120V to the igniter? If the voltage is there, but it is not glowing, replace the igniter... GE Range Stove Oven Igniter WB2X9998
Jan 02, 2016 | GE Cafe CGS990SETSS 30" Free-Standing Gas...
CGS980SEM1SS GE Cafe gas range which is 2 yrs 2 mths old. Oven shuts off after 5 mins, 10 mins, 20 mins...and at any temperature. All control panel functions cease to work, and most of the times the stove...
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then 1120 ohms then it should be replaced however, if it reads between 1080-1120 ohm then check the control and door switch and replace the part that is bad. You can also check the wire harness from the control to the electronic board. Hope this helps...
Daniel
Feb 11, 2011 | GE Cafe CGS980S Kitchen Range
GE Gas oven not coming on (ignitor not glowing at all) ge jgsp28sek4ss Broiler works, stove top works, oven igniter not coming on Thanks Jim
The ignitor just needs replaced . you can find the parts using your stove model # . its two screws and a wire to replace .
Feb 05, 2011 | GE Kitchen Ranges
Hi I have a GE cafe brand gas stove and decided to clean the burners the other day. I cannot get rid of the brownish stains around the burner. More so, I used the chemical solution that came with the...
merry christmas
Dec 22, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE XL44 gas stove the oven will not stay lite why?
That's bad. Sounds like the burner is dirty.
and the gas belive it or not is blowing the polit out it hit it so fast. The gas can't go in the burner. There should be two screws that hold it in place take it off and clean. See if that will work. Let me know.
Ken
Sep 20, 2009 | GE Spectra JGBP35 Gas Kitchen Range
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
Scrubbed the gas fixtures on stove top, won't light
this is something I do not recommend you do yourseelf, but there is a adjustment screw on the front under the panel near the knobs little screw that can be adjusted
Feb 07, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GAS STOVE
yep replace the bottom ignightor take out the rackes remove the two bott screws in the oven remove the bottom plate and just keep going down
May 21, 2008 | Kitchen Ranges
GE Cafe CGS990SETSS 30" Free-Standing Gas Double Oven With Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
