Question about Tricity Bendix AW1000W Front Load Washer
My servis washing machine turns and empties but wont spin machine isnt spinning
  • Tricity Bendix Master
  • 3,463 Answers
I suggest you remove motor and check the carbon brushes fitted at the end of the motor, if they are less than 2-3mm long ,they need replacing.
Plz rate my solution
Thanks.
Posted on Jan 07, 2009
My zanussi zwg6141p wont spin and cut out during wash?
replace the carbon motor brushes and retry if it wont spin usually the water isnt taken out fast enought to satisfy the vaccume switch so its the pump the switch or an air lock
so empty the machine totally and expell all water from all hozes and check the waiste is aok for flow no jams your left with either the pump motor issues bits of b.a wires or the main motor brushes
Mar 05, 2015 | Zanussi Washing Machines
My Kenmore HE2t washer is stopping about 8 minutes into the cycle (any wash cycle)..completely turns off. I can run rinse and spin then and it completes the cycle. No error codes when it turns off. W
htc sensor isnt working i would recon
perhaps the element isnt getting power
did it trip your circuit breaker
some times the htc fails
all you get is machine stop because the heater is not detected
if it spins rinses and empties in a timely manner
then all thats left is the heater system
Jan 09, 2015 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Drum wont turn or empty water
depending on the model, a broken belt is a good possibility. if you hear the motor going, but the bowl isnt moving, that is a sign of a broken belt, it is also possible the motor has failed.
Nov 11, 2013 | Washing Machines
My maytag atlantis cycles but wont spin out. It spins slowly then shuts off but leaves wet clothes and water in tub.
First determine whether all the water is pumping out before it goes into spin. If not, check the pump and drain. If its not spinning fast enough with an empty tub check that there isnt any article of clothing caught between the inner and outer tubs or tub top ring. If thats ok check the clutch by turning the main drive pulley CCW. Substantial drag should be felt before the basket overcomes momentum and begins to turn. There is no repair for the clutch on this machine. The transmission must be replaced.
Jul 14, 2011 | Maytag Atlantis MAV6451 Top Load Washer
F&P GW712 washing machine, the machine washes and when it gets to the spin part it wont spin, it tries to and then a continuous beeping sound and too lights long wash & short wash comes on until...
hello what might be happening when it's going through the cycle and come to the spin part there may be not enough water empting out from the pump causeing it not to spin also there may be a fault with the module board the control the motor speed also brushes on the motor can cause spin problems hope it
regards
shaun
May 01, 2011 | Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Servis easy logic 1600 wont spin
servis easy logic 1600 wont spin just moves the drum half a turn and stops but repeats all the time
Aug 17, 2008 | Washing Machines
Servis easi logic 1600 washing machine not working
my servis eai logic 1300 will not rotate half way through the wash but will still spin and dry etc please advise.
May 09, 2008 | Washing Machines
Servis washing machine m6011s
Have you checked drum sprinds
Dec 02, 2007 | Washing Machines
Tricity Bendix AW1000W Front Load Washer Logo
320 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
