Question about E-Machines eMachines Monitor E15T4
Monitor only stays on for 30 sec. & then goes off then if I remove the power cord & re-power it up it comes on for another 30 sec. then goes back off
  • 1 more comment
  • juli28428 Jan 07, 2009
    Mine stays on a little longer than that but then goes off and I cannot turn it back on - it's as if the power button will not work. This happened after I'd used the monitor about two weeks past the first year ater I'd purchased it. I'm really bummed out with emachines.
  • Anonymous Jan 12, 2009
    Same problem. Really sick of Wal Mart selling inferior products. You shouldn't have to give up quality just because you want to save a lil money during these trying times. Would not reccomend emachines to potential PC buyers. Pay the extra 50-100 for something with a better rep.
  • willpablo Feb 07, 2009
    hello i have an e machines et15t4w-eu monitor with same problem , turn it on its ok for few seconds then goes dark, if i take out the power supply and re connect its ok for few seconds then goes dark again, there is also a slight buzzing coming from it when it goes dark can u please help??? the light on it is always blue as has never changed colour.
  • 180 Answers
Howdy folks. There are only 3 things that can go wrong with a screen. Since you both are experiencing the same symptoms, let's ask the same question: When the screen goes blank, is the power button still green or is it orange? A green light indicates a good power supply and a bad screen. An orange light indicates a bad power supply but a good screen. I used to take them apart and try to fix them but they just aren't worth the trouble because they are so inexpensive nowadays.
Either way, I'm the bearer of bad news. It looks like you'll both be getting new screens. Please don't hold it against me when you rate my solution! ;-)
Posted on Jan 11, 2009
Why does red light come on and stay on
remove the power cord wait 30 sec then plug it back in
Aug 06, 2014 | Microsoft Xbox 360 Console
Reset password
Easy enough to resolve,try this procedure,just remember do not remove pressure on reset button until finished or you will need to do this over again,please follow these steps in order.
1 )with power cord plugged in press and hold reset button 30 sec
2)remove power cord and continue to hold 30 sec
3)plug power cord back in and hold 30 sec.
remove finger or whatever you used to hold button
You should now be able to go to network genie or your web page with router cable plugged in and type
user name is admin
password is password all lower case
you should be able to set up your router.
Apr 19, 2014 | Linksys Wireless-G WRT54G Router
Black screen
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
Mar 02, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
When monitor is turned on it says no signal for a second or two. then screen goes black and stays that way. monitor and cord have been tested with another cpu and worked
then your pc's video card has likely gone bad. first try powering off the PC, wait 30 secs and power on again. If you still get no display, and you know the monitor is good, you have a bad graphics card or some other hardware fault in the PC.
Oct 03, 2009 | Everex GA3400 Refurbished AMD Desktop...
I have an SVA LCD Model VR-17S Monitor that has a black screen
Sounds like the Backlight balance sensor circuit is shutting down the inverter supply. A weak bulb can cause this or a malfunctioning sensor circuit can cause it too. Best method to troubleshoot is to substitute good bulbs; if it still shuts down, look for a pair of small electrolytic caps on the inverter board near the bulb sockets. They may be weak.
Monitor Mike.
Jan 03, 2009 | Computers & Internet
When i hook up my comp the monitor stays black...whats going on?
Try remove your VGA card and reinsert and test. And if the problem persist then test your monitor to the other PCs and if it displays then it could be the card is bad or the monito's resolution was ajusted causing to be uncompatible for your PCs resolution.
Nov 22, 2008 | Computers & Internet
Liquid Video monitor goes black after 30 seconds
Capacitors on the power board inside the lcd monitor have blown they can be replaced with new ones and the monitor should return to normal operation.
service center or if you feel capable you can do it your self with a soldering iron and the correct caps that have blown you need voltage and micro faradays usually 25 v at 470 mfd (u)however monitors use different kinds and voltages can be different it will be marked on the side of the damaged capacitors.
Nov 11, 2008 | Computers & Internet
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
Oct 28, 2008 | Computers & Internet
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
E-Machines eMachines Monitor E15T4 Logo
206 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
