Question about Bose Audio Players & Recorders
I have a AWRCC5 model Bose music system. No manual so I cant change the time display using the remote,
The remote just has the words Time - + When pressing either of these nothing happens even if I press either of them for 5 seconds while pressing the tuneing buttons forward or back.
SOURCE: Daylight savings time - cannont change time
hold down either the + or the - depending on how you want to change the time. If you just hold the button down for 3 to 5 seconds the time will start to go up or down.
Posted on Nov 04, 2007
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
SOURCE: Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Posted on Apr 10, 2008
SOURCE: Clock on Bose Radio
Push & hold Clock Set Button. While holding, push On/Off button,
Thank You, FixYa Community! Thank you! Thank you! Boy, that one was not obvious.
Posted on May 03, 2008
Buttons to change time not working
Bose Support - Owner Manuals
worldwide.bose.com/axa/en_au/...manuals/page.html
Bose CorporationFind Bose product informations for headphones, multimedia speakers, stereo ... IV ·Wave® SoundTouch music system IV · Acoustic Wave® music system II ... manualsfor home theatre systems and speakers ... manuals for stereo speakers ...‎Music systems - ‎Home theatre systems and ... - ‎Headphones - ‎Multimedia speakers
[PDF]The Bose® Wave® Radio Owner's Guide
products.bose.com/pdf/customer.../wrv3_guide.pdf
Bose CorporationThese CAUTION marks are located on the bottom of your Wave radio: ... the user to the presence of important operating and maintenance instructions in this.
Nov 01, 2015 | Bose Wave Radio
Bose music system remote is inconsistent.
The notoriously unreliable SMD capacitors which Bose installed are long defective. That's just the start of your problems.
You'll need to replace those defective capacitors with much higher-quality units than the original.
Only a tech experienced with SMD work should attempt this repair.
Replacing the PCB will solve your problem for only a short time, as you are just getting the original standard junk again, but new.
Dec 29, 2014 | Bose & Wave& Music System
BOSE LIFESTYLE 50 REMOTE CONTROL NOT WORKING
FOR THE BOSE LIFESTYLE 50 SYSTEM (Model P1 - Personal Music Center remote)
You can re-calibrate the remote first by following the steps below:
1. press and hold down on the display screen in the top middle area of the remote
2. After a few seconds the word CAL will appear in the middle and the word SOURCE will appear in the top left area of the remote.
3. Press the SOURCE button.
4. The word KEYPAD will appear in the top right area of the remote
5. Press the KEYPAD button and a small circle will appear in the bottom right of the remote.
6. Press the Circle
This should've recalibrated the remote.
If you need to relink the remote to the system, HOLD down the mute button while having the remote as close as possible to the unit. You will hear a beep . Release the button, after a pause , you will hear the remote beep twice.
This re-links the remote to your system
If the backlight is not working, your options are
1. Spend $349 and get a new one from Bose Or
2.Spend $220 and get a used one on E-bayOR
3. Use your remote with the lights on so that you can see the display :-)...the cheapest way OR Invest in an LED Book light that you can clamp on the remote and use that for your light ($9.99)
Sep 10, 2012 | Bose LifeStyle 50 System
The problem began with the unit not ejecting, now it won't accept the cd. Who will repair in Scotland ? ( Bose radio /cd AWRCC5 ) Thank you
this is sort of problem which u should go in service center that might be listed in user manual if not then write to me by clarifying exactly where u live to give u ur nearest service centre address or number
Regards
Jul 04, 2010 | Bose & Wave& Music System
How do you reset the clock
Turn on the lights in your room and it will be obvious. On the Bose Wave Music System clock radio remote there is a + and - button labeled "time." This is how you set the time. Hold either the + button to move the time forward or the - button to set the time backwards. You don't need to push any buttons before you press the + or -. After you have set the time you can press the "alarm time" button to lock in your changed time.
The standard remote does not have a back-light feature. However, if you bought the optional larger remote and try to set the clock in the dark with the back-lit buttons, you won't be able to see the word "time" above the + and - buttons. This is because the word "time" is written on the metal part of the remote, which does not illuminate with the back-lighting feature.
Nov 01, 2009 | Bose Wave music system large Remote...
Radio doesn't work at all
are you getting and static sound out of radio? and are you sure the unit isnt staying on c.d. and not switching to radio when disc is removed?
Oct 02, 2009 | Bose Wave Music System CD Shelf System
Bose wave music system
Check remote and replace its batteries.
Does this remote work on any other device?
Sep 16, 2008 | Bose Wave Radio
Bose 023795
Water damage on these types of devices is rarely recoverable.
You can contact Bose directly to enquire about how to order spare parts.
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/faq/product_faq8.jsp&ck=0
Jerry G.
Jul 15, 2008 | Bose 023795 LCD Touchscreen Remote Control
Inoperative Bose Wave Radio
You should contacty Bose directly to find out about service. There may be a fault in the power supply, or one of the circuit boards in the unit. This will require proper troubleshooting and parts replacements.
Jerry G.
Oct 27, 2007 | Bose & Wave& Music System
348 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
