Question about Homelite Electrical Supplies
Portable homelite Generator 5.5kw no output - Homelite Electrical Supplies
5 Suggested Answers
mamicheddy
  • 79 Answers
SOURCE: Generac portable generator doesn't produce power
Remove front cover on the genset and you will see the brushes and rings. Clean the rings if black with emory cloth and inspect brushes. Flash the fields by apply a 12V battery to the brushes. the brush closest to you or the bearing is connected to the positive side of battery and the back brush is negative. You have to do this with genset running. You should notice your voltage climb up to over 50Vac maybe even over 100Vac. Make sure to use rubber gloves when flashing fields and keep hands away from rotating parts. if voltage does increase when flashing the the voltage regulator is shot. If voltage does not climb then you will need a new genset or generator end.
Posted on May 15, 2009
  • 491 Answers
SOURCE: Homelite portable generator, LRIE4400...no out put
If the engine is running but no output from the plugs....the VERY common problem is loss of magnetism in the generator after storage.
With the generator off.........
Look at the side of the generator part.....do you see a small + and - on any terminals?
You may have to take a cover off.
Take a 9 volt battery and momentarily put current from this small battery through these terminals.
Now.....start her up and check for power at the plugs.
This fixes 75% of "no output" after being "stored" generators.
Posted on Sep 09, 2009
Testimonial: "you learn if you ask someone that know's...allan"
freetek
  • 5568 Answers
SOURCE: just up graded from a homelite 4400 to a craftsman
Some manufacturers tend to fudge the numbers and throw around the 'peak' output power as continuous and it isn't. Peak (or surge) is the power a generator will handle as starting current (for example) for a motor and can be 120-140% of the actual continuous power.
Check you owner's manual, find the detailed specs which will normally contain the maximum continuous current rating. If it is listed separately for 120 and 220 (240) volts look for separate current ratings for each output.
By multiplying the current(s) times the output voltages you can find the total resistive output into a purely resistive load such as an electric heater.
For example: 120VAC X 20 A=2400 watts. If other outputs are available such as 220VAC, multiply its current rating: 10A. or 2200 watts Adding those two results 2400 2200=4600 watts will give you the rated power of a unit.
You can also recognize stupid power claims if the engine's horsepower is given. One (US) HP = ~746 watts. Since no generator is 100% efficient, its a fair rule of thumb to guesstimate the available electrical power at ~70% of the engine's rating (although, this is often also wildly optimistic). 10 HP X .7= ~746 X 7 or a bit over 5,000 watts.
Posted on Oct 03, 2010
2wiseman08
  • 14 Answers
SOURCE: why won't my homelite generator output current when running?
If the brushes are bad on the armature you will not get power
Posted on Jul 09, 2012
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
    If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
    May 13, 2014 | Briggs & Stratton Briggs and Stratton...
    Onan 7000 generator runs but does not produce electric to rv
    First verify that the breaker for the outlets is not tripped and make sure that the generator is running at full operating speed. let it run for 5-10 minutes and check for output power. If there is nothing, there are two possible problems. One could be that the automatic voltage regulator is bad. The other is that the field needs to be flashed - a high possibility if the generator has not been run in a long time. There are many videos on the internet that show you how to solve both of these problems. Just do a search for No output from a portable power generator.
    Mar 19, 2014 | Watts Onan Portable Generator - 4000 ,...
    Low voltage output from generator
    if there is output but the voltage is low check the voltage regulator
    Sep 06, 2012 | Robin Subaru SGX7500E Portable Generator
    I have a hg 6000 homelite generator, runs great but does not give me any power. i used it a year or so ago an everything worked fine. got a lil smoke from where windings are. the generator was made in...
    Hi and welcime to FixYa. I am Kelly
    This is going to sound odd but.... this is how it it is recommended to field flash and inverter type generator. (Brushless) The steps are to (not kidding...) use a male mail interconnecting wire from your house wiring and plug in your generator and turn ON the main CB for 1 minute.
    If this does not work.... See steps below amnual links.
    Owners manual link: (Click on get manual)
    http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/hg6000_1.html
    Or try this direct link:
    http://lawnandgarden.manualsonline.com/support/homelite/portable-generator/request-manual-299128
    This is a brushless generator... Not sure what the smoke was but... the yellow wires are for the capacitor winding. If you probe the capacitor terminals with one of the wires disconnected with a meter on R x 10,000 you should see a brief jump in resistance and then the meter drifts to infinity.
    reverse the test leads and test again looking for the same result.
    Next read resistance Yellow wire to Yellow Wire (Stator capacitor loop check) It should read low resistance
    Also read Brown wire to Brown wire. This is the DC stator loop check. Is should read resistance.
    Main winding checks Red to Blue and White to Brown that goes to the main breaker. OR Turn the Main breaker on.. White to lower left pin of 30A 4 pin output recepticle. Bot red to blue and White to Brown MUST read low resistance
    These are all the checks except the rectifier and the rotor. You will probably find something during the above tests. If not... respond here and I will pass on the rotor and diode tests.
    Kelly
    Aug 27, 2011 | Electrical Supplies
    Need to know color code for 220VAC receptacle, so can wire up an output cord. Had no cord with the generator. Have LRE 5500 portable generator. Have new 4 prong plug.
    Hello Arthur,
    For 220vac, you will have 2 blacks or Red and Black (line). The white is neutral, green / bare is your ground.
    If you look closely at the plug, the contacts for the line will have either black screws, or be labeled as L1 and L2. Neutral will have a white or silver screw, may be labeled as N, and the ground will be green or silver, labeled as Ground, Gnd, E, or Earth.
    Aug 26, 2010 | Homelite Mighty Lite Lawn Trimmer
    Homelite generator model # LR 5500 not producing electricity
    I have the same unit and same problem.
    I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
    Mar 07, 2010 | Electrical Supplies
    Homelite portable generator, LRIE4400...no out put fr unit..has been discontinued fr a few yrs..no parts available..known fr circuit board failure..my dad's , maby 50hr on unit..how can I bypass..or obtain...
    Sep 09, 2009 | Electrical Supplies
    No output from my generator
    check breaker, your outlets should be like a gfi
    May 21, 2009 | Coleman Powermate Premium Plus 6250W...
    Electrical Supplies Logo
    216 people viewed this question
    Top Homelite Electrical Supplies Experts
    wadingriver
    wadingriver
    John Trevino
    Lawrence Oravetz
    Are you a Homelite Electrical Supply Expert? Answer questions, earn points and help others
