Question about GE Washing Machines
Motor not working
New clutch now motor doesn't work
    Top Expert:
  • GE Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
Kawasaki vulcan clutch
Sounds like the transmission may be bound up inside.
Jun 06, 2013 | Motorcycles
Aficio MP161 Toner bottle doesn't turn to add toner.
How many copies on that machine? The photoconductor unit on that model only goes 45,000 copies. If the machine wont tone up and the pcu is old i would replace it and calibrate to see if the problem goes away. The pcu is cheap for that model. Start there would be my advice.
Jul 23, 2012 | Ricoh Aficio MP 161 Black and White Copier
Zanussi fj12544 fills but won't wash
see this probably cause:
t doesn't pump or spin
frozen pulley or broken belt, replace
It pumps, but doesn't spin
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
It spins only with the lid closed
lid swtich defective.
Jun 18, 2012 | Zanussi ZWF1420W Front Load Washer
Where's the fuse for the AC on 98 Olds 88?
So what does the fuse that blows, protect?
You need a wiring diagram & start to test
the components most likely to cause a high
current draw & blown fuse.
Don't keep replacing it.
You know the fan control circuit works, but the
compressor doesn't stay on. Did you monitor
the compressor as the fuse blew?
May have a module for compressor & fan
If so one side failed
The compressor clutch could be bad
May 24, 2012 | 1998 Oldsmobile Eighty Eight
White z-200 pto switch wont engage mower blades, sputters and shuts motor off.
Electric clutch is going bad and mower doesn't have enough power to run the clutch. Clutch is running tight new clutch is around 270.00 dollars
Apr 11, 2012 | Oregon Scientific Electric PTO Clutch for...
The motor runs on my Singer Merrit 8734 but the needle doesn't move.
if you have to undo the clutch to wind the bobbin, then try undoing the clutch again & then retightening the clutch & see if that helps & if it doesn't help the machine needs to be checked
Mar 26, 2012 | Singer Merritt 8734
Why does the 30 amp circuit breaker behind the battery box on my 1990 fatboy click once when i push the ignition button? The bike won't start.
Try to reset the circuit breaker. also check for an earth fault on the starter motor .If this is not a circuit breaker and is a relay, you should make sure everything is ready for a start, (ie : in neutral, sidestand up and clutch in and that the battery is charged.) the neutral light being "on" doesn't mean it is in neutral. I hope this helps.
Mar 08, 2012 | Motorcycles
You can hear the starter spin but its not turning over the motor? on a 1993 cbr 600
If the starter clutch gets gummed up it doesn't work properly. Take it off and clean it. If that doesn't work you will need a new clutch. The clutch is at the outside end if the starter motor. Go to the website for a diagram of the starter and clutch assembly. www.babbittsonline.com tombones49_256.gif
Aug 20, 2011 | 1993 Honda CBR 400 RR
99 mercury cougar replaced power window motor and switch window still does not work
That doesn't seem possible does it ?
You remove the inner door panel
You think the motor may be bad,so you unplug it,
knowing it is a DC Motor & can be hooked up either
way & will run in either direction
You put 12 volts to it. Doesn't work ,sounds bad,you
install a new one
Now you need power from the switch to run the new motor,
so you work on that
The switch can be disconnected & tested with an OHM Meter
& if worn,you replace that
You checked the fuse before you started & knew that wasn't an issue,
because all the other windows worked
So what did you mis ,short of having no wiring diagram, to make
things a lot easier?
Aug 04, 2011 | 1999 Mercury Cougar
Motor works and spins but as soon as the drill touches the wall drill stops but motor keeps going.
Check the speed switch on top - sometimes it doesn't fully seat in the 1 or 2 position. Switch it to the opposite setting, run it, then switch back, until it seats properly. Also check the clutch control ring for the same issue.
Jul 21, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Washing Machines Logo
14 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
