Question about West Bend (58036) 36-Cup Coffee Maker
30 cup coffee maker
I have misplaced the stem and basket inside the coffee maker and I need to purchase a new one.
  • 2,976 Answers
This is a direct link for the parts you need.
Posted on Jan 04, 2009
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
I have a 22 cup coffee maker and the stem got lost. the part that hold the coffee basket in place
Assuming you have a model 58602, the only 22-cup urn listed on West Bend's parts site, the news isn't good. The parts page for that model says the stem is no longer available. Checking a few other parts links all turn up the same answer. You might try checking locally at thrift stores or on Craig's list to see if anybody has one available.
Sorry I can't do more, but thanks for using Fixya!
Jan 21, 2010 | West Bend (58036) 36-Cup Coffee Maker
Cuisinart DGB-900BC filter basket brew pause spring came out. How do I fix it?
You can push the soft rubber stop or valve back on the plunger stem with the flat side down. It can pull out if you are rough with it or if the plunger gets stuck in your dishes drip rack. But if it is torn you need to order a new basket because I don't think the parts are sold separately.
Jan 12, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Whay is the coffee to water ratio per cup?
I have the Regal 10 to 30 cup model K7030C.
Instructions read as follows:
(5-oz serving) ( 8-oz dry measure)
10 ........................2/3 Cup
20.........................1 1/4 Cups
30.........................1 3/4 Cups
Hope this helps
Mar 06, 2009 | Regal Ware (RW58230R) 30-Cup Coffee Maker
How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Nov 14, 2008 | Regal Ware 426473 Black Satin Coffee Urn...
Your coffee is too finely ground for your basket. 2 solutions: buy "regular" ground coffee from now on, OR use filters inside the basket. Many 30 cup or 45 cup maker's baskets are sized so that a normal filter, flattened-out, and a small hole torn in the middle will fit into basket and prevent the grounds from passing through.
Oct 05, 2008 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
Aug 09, 2008 | West Bend (58036) 36-Cup Coffee Maker
West Bend (58036) 36-Cup Coffee Maker Logo
64 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
