Question about Thomson WSP740 2 Wireless Speakers
Transmitter not working wsp740
Works for about 20 secs then stops
U817a loses connect to the remote control short after starting the droneflight
I would probably check to see if the crystal on the transmitter is connected properly and the wire in the reciever is clean and all the way in. Also if you're really close to a very strong power source consider moving away a bit (but your system is a 4ghz system so that shouldnt be a problem)
Dec 26, 2013 | UDI U817a 2 4ghz Ch 4 Axis Gyro Rc...
I have a Saab 2.2tid linear (2003). the central locking system has just stopped working completely, there was no warning to suggest its the battery in the key.. before it stopped working altogether it used...
THE SAAB 9 -3 REMOTE BATTERY HAS TO BE REPLACED AND REPROGRAMMED AT THE DEALERSHIP.THE SAAB 9 - 5 YOU COULD REPLACE REMOTE BATTERY AND REPROGRAM OR SYNCHRONIZATION BY PRESSING REMOTE KEY BUTTON UNLOCK BUTTON AT LEAST 4 TIMES TO REPROGRAM KEY REMOTE TRANSMITTER.
Mar 04, 2011 | Saab 9 3 Cars & Trucks
Re: Hahnel Giga T Pro Wireless Remote Control Hi,
I have exactly the same problem. This product seems faulty or something? My transmitter does not go on and I also can't work out where the batteries go besides if I had to open the thing up and check whats inside (which i do not want to do). The strange thing is that when I plug the transmitter directly into the camera it works as a (wired) remote. Weird. I think I should just have paid the extra money and gone with the original Canon intevelometer instead of this two-bit massed produced piece of shyte. Let me know if you figure out how to operate this frustratingly **** product.
Aug 12, 2010 | Cameras
The remote not programmed
** All transmitters must be programmed at the same time! Max of 4 transmitters can be programmed. **
- Keep the driver's door open.
- Electronically unlock the doors (Switch on door or working transmitter).
- Turn the ignition from OFF to RUN 8 times within 10 seconds, with the eighth turn ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
- Within 20 seconds, press any button on an transmitter, and the doors will lock and then unlock to confirm that each transmitter has been programmed. Repeat this step for each transmitter.
** If the door locks do not respond for any transmitter, wait several seconds and press the button again. **
- To exit the programming mode:
-- Turn ignition to the OFF position.
-- Let the 20 seconds expire.
-- The maximum number of transmitters have been programmed.
Just remember that you must also re-program your currently working remotes at this time also as if they are new since prior remotes are erased. Hope this helps!
Sep 13, 2009 | 2006 Ford Taurus
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
Jun 11, 2009 | 1998 Honda Accord
Garage door opener transmitter/receiver compatibility
Press and hold the homelink button and wait till the red light flashes slowly,but don't release it. Now hold a working remote 3 inches away,press the remote button and hold it.When the red Homelink buttom fllashes quickly, release both buttons. Now go to the opener and push the learn button. Now go back to your car and press and hold the Homelink button. You will see the lights on your opener flash. Now your Homelink button should operate your garage door.
Jan 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Set the keyless entry
TS06 DEC 05 Keyless Entry - Transmitter(s) Inoperative
There was a recall in DEC. 05 for this particular vehicles remote transmitter system....though im not sure if they would do service free of charge now...
Moving along...if you have no working transmitter, you have to do the following to get it working again:
* Ensure vehicle audio PIN number is known or audio PIN security system is deactivated prior to battery disconnection.
* Ensure a door is open
* Disconnect the negative battery cable, wait minimum 5 seconds then reconnect
* Within 20 seconds of reconnecting the battery cable, insert the keyin ignition then cycle the ignition key from the "ACC" position to the"ON" position 20 times, leaving the key in the "OFF" position after thetwentieth turn.
* the vehicle's indicators will flash 20 times to indicate successfulentry. NOTE: Should the indicators fail to flash, wait 5 seconds thenquickly turn the ignition switch from the "ACC" to "ON" position 10times, leave the ignition "OFF" after the 10th turn and wait 15 secondsthen recycle the ignition switch 20 times.
* the vehicle's indicators will flash 20 times to indicate successful entry.
* within 10 seconds of the indicators having ceased flashing, press the button once on each transmitter.
* turn the ignition key to the "ON" position to lock in and exit from the programming mode.
And if you have even 1 transmitter that does work, its not nearly as difficult:
* ensure a door is open
* remove key from ignition
* lock the doors using the transmitter
* unlock the doors using the transmitter
Within 20 seconds of unlocking, insert key in ignition, turn theignition key from the "ACC" position to the "ON" position 20 times,leaving the key in the "OFF" position after the twentieth turn.
The vehicle's indicators will flash 20 times to indicate successful entry.
Within 10 seconds of the indicators having ceased flashing, press thebutton once on each transmitter. Once finished, turn the ignition keyto the "ON" position to lock in and exit from the programming mode.
Hope this helped,
Jem
Nov 12, 2008 | 2004 Suzuki Verona
Cordless mouse and keyboard wont work together
Hi, after experimenting a little i have fixed my problem and I think I might be able to help you.
First, try press the connect button on the receiver.. Hold it for 20 sec (might not be necessary).
Then, press the connect button on the mouse and hold it for 20 sec (is necessary)
Next, wait 20 sec (is necessary) then press the connect button on the receiver but do not hold
Finally, press and hold the keyboard button for 20 sec.
Sep 28, 2008 | Logitech Cordless Mouse
Reprogram remote
xl-7 programming instructions first you need to stuff your head up under the dash and locate your module drivers side upper corner under dash does it say programmable transmitter (the first models had no programable modules) if it says that then......
1 confirm all doors are shut and key is out of ignition
2 open drivers door insert key and turn to on within 10 sec
3 turn ignition switch to off in 10 sec
4 push and release drivers door switch 3 times in 20 sec
5 turn ign. switch to on in 10 sec
6 turn ign. switch to off in 10 sec
7 press and hold lock and unlock button on transmitter for 5 sec within 20 sec of step 6 alldoors will lock/unlockto confirm correct process
8 press lock unlock buttons on second remote within 5 sec after step 7 once again all doors will lock/unlock to confirm
9 to add another remote up to a max of four repeat steps 1 through 8 this was taken directly out of an owners manual supplement that comes with a new keyless entry kit (part number for a xl-7 or grand vitara can't remember which one it goes to but it works on either one is 84900-67810) which you would have to purchase if yours is not programable these instructions are the same for vitara, grand vitara, xl-7 and the esteem hope this helps
Jul 05, 2008 | 2002 Suzuki Grand Vitara
Reset dvd to
Turn down the power . then turn back on and hold the stop button for 20 sec. this should reset the player
May 26, 2008 | Cyberhome CH-DVD 300 DVD Player
Thomson WSP740 2 Wireless Speakers Logo
44 people viewed this question
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
