Question about Sims Audio Players & Recorders
I need the how to use
Korean. I changed new battery and it works. But I don't know how to use.
  • 27 Answers
Search your model # to see if there is a manual available online.
Posted on Oct 31, 2012
My Korean international student has an LG U+ 070 internet phone. She used it for about 5 months until it started to display "unauthorized" and she could no longer use it. I don't know what to do
Best check with the service provider as to why the service was terminated Check that the entry code is still valid by calling the service provider on another phone and discussing the problem
Feb 25, 2013 | Cell Phones
My two idiotlights don't come on when you turn key on and head lights don't work. have replaced ing. switch with no change
check for a fuse near the engine to tractor wiring connector. check battery cables for looseness & corrosion. tighten the ground cable where it connects to the chassis and inspect the engine to chassis bolts. loose connections can cause backfeed problems, such as when you step on the brake pedal in your car, and can then turn on the radio...
Dec 16, 2012 | Garden
I have remote 00104M for Samsung tv, I need to change language from Korean to English, can't read Korean
download instruction manual www.fitness.manualsonline.com or www.retrevo.com and follow the steps.
sincerely. God bless you
May 06, 2012 | Samsung Televison & Video
Problem with the Compaq Presario PC Notebook I want to change the language of my laptop from Korean to English
This may vary slightly depending on your operating system but if you goto the start menue and select Control Panel, then you may have to select "Classic view" (or the real control panel not the ridiculously dumbed down verson designed for people who shouldn't be allowed to use a computer) then select languages and regions and set them accordingly. Of course I can't tell you what these will be labled in Korean as I don't speak Korean.
Aug 17, 2011 | Computers & Internet
My phone keeps saying "use
the LG chocolate is bad and knowen by battery problem and low capacity,, with your problem you must get new battery with best quality but I recommand you to change your mobile when you go back from Puerto Rico and have a good vacation.. ;)
Jul 20, 2011 | LG CHOCOLATE VX8500 Cellular Phone
Battery on a 2005 Mustang went dead. Had a Jump to get the car started. Drove & speedometer & odometer worked fine. However, I had Triple AAA install a new battery & now they don't work. ...
Did AAA clean the battery cable connections when they installed your battery? Did you check the fuse for the insrument panel?
It could be just bad timing or a coincidense but I am more likely to think things are connected. If your gauges worked after jump starting your car, but not after AAA changed the battery, something changed or was left disconnected.
Jul 03, 2011 | 2005 Ford Mustang
Will a 12 volt slide battery work in my 9.6 volt Black & Decker Firestorm drill. The 9.6 volt batteries don't seem to be made any more. I don't think I paid a lot more for the original drill...
This close to father's day you should be able to buy a new drill for about the same as a battery. The 12v would overheat the motor if you ran it for an extended period.
Jun 13, 2011 | Black & Decker 9.6v Cordless Drill/driver...
I got the garmin 1490T because it was supposed to have voice support for korean but in the options, it does not show up. For some reason the it only shows up to French (julie's voice) and I cant...
I don't know if garmin have a Korean voice. They probably have and yes it is possible to add voices to the satnav. You need to download and install WEBUPDATER to your computer. It can be downloaded from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
When it's installed connect your satnav to your computer and run the WEBUPDATER program. It will search for software updates. Install any that it finds and when it's finished it will give you the option of downloading optional downloads. These include voices. Select the voices you want to download and they will be downloaded to your satnav.
You need to disconnect the satnav safely from your computer, like a memory stick or external harddrive. When it's disconnected start up the satnav and press TOOLS, SETTINGS, LANGUAGE & VOICE. Select the voice you want. All the downloaded voices should be available to you.
Jun 08, 2011 | Garmin nuvi 1490T GPS Receiver
Hi i need to set gprs setting manually on my mileston xt720 i check the phone but don't know how to change it .please help
Firstly, bear in mind your carrier's APN settings. Contact they, in case you don't know such data for sure.
Then, go to 'Menu > Settings > Wireless & networks > Mobile networks > Access Point names'. Once there, press 'Menu > New APN', and fill in a 'Name' for it, and, at least, your carrier's data under 'APN', 'Username' and 'Password'. Then, press 'Menu > Save'. Press the back button as many times as required for you to reach the home screen you were in, prior you've started making these changes.
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Regards,
Carlos
May 07, 2011 | Motorola Mobility MILESTONE XT720 Cell...
99 people viewed this question
Top Sims Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sims Audio Player and Recorder Expert? Answer questions, earn points and help others
