Question about GE Refrigerators
Should the heater come on every time the compressor stops running on a ge gss201embww???
    Top Expert:
  • GE Master
  • 9,472 Answers
The cycle is controlled by an electric or electronic timer: For every six to 12 hours of compressor operation it runs a defrost heater element for about 15 minutes to a half hour.
Posted on Nov 01, 2012
Whirlpool ed22mk xl fans run, starter is a solid state starter ge ic-13, 3arr42a2. Click, compressor vibrates, sounds like it us running, click, compressor stops.
call the technician for a proper diagnosis and quote
could still be the starter capacitor failure or a compressor seizure
Aug 28, 2016 | GE Refrigerators
GE GSH25GGCBBB COND FAN NOT RUNNING, COMPRESSOR NOT RUNNING
If the heater HAS shorted (burned look) it CAN destroy this board. FYI: Usually, heaters burn because the defrost termination thermostat is defective. The heater can literally melt the aluminum shield if this is the case.
ALSO: If your compressor won't run after replacing the heater and thermostat, WAIT for about an hour (with your fridge plugged in) before deciding this board is bad and preventing the compressor from coming on. Mine miraculously started...after 1.5 hours. YES.
It has a pair of freezer sensors (along with the simple defrost termination thermostat) with a microprocessor control that apparently brain fades sometimes.$$ saved.
Oct 15, 2013 | General Electric GSH25JGDBB: ENERSTAR 25.3...
Our GE sss25kfmdww "freezes up" and then stops refrigerating
Most times on that model the defrost heater and defrost thermostat will need to be replaced. The timer is built into the mother board and for some reason they are not the most likely reason. The defrost heater has a glass tube around the element and easy to spot if burned out. If you replace one part you should replace both. Now is a good time for you to do a little reading about your model. I will give you a link to the service manual and a page with a tech sheet, Sea Breeze
Dec 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side freezer not working - ice buildup
check the defrost timmer if it is working you need a defrost heater you can manually turn the defrost timmer to check the heater the timmer turns off the compressor and on the heater 2 or 3 times a day the timmer is a box with a round knob sticking out of it turn the knob tell it clicks look under the front for it or in the back most refrigerators have a wiring diagram on the back or by the compressor
Oct 20, 2009 | GE Refrigerators
GSS201EMBWW Unit is freezijng up.
Most likely part number WR51X10101 Defrost Heater has burned out. Unplug and remove the rear panel inside the freezer. Defrost with a hair dryer and examine the defrost heater and look to see if burned out, It has a glass tube around the heater element and will be easy to see if burned out. If you need to replace the defrost heater you should also replace the defrost thermostat part number WR50X10054 If you don't see a problem with the defrost heater and I will instruct you on how to manually defrost to test the heater and defrost thermostat. Check for bad connections on wiring to heater and defrost thermostat. Your model has a mother control board part number WR55X10942 We may also need to check that because it does the thinking and determines the time for defrost. Let me Know what you find, Thanks, Sea Breeze
Oct 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side TFX22RLC
If the condenser fan is not running while the compressor is running could damage the compressors overload. Yes it's a serious problem if not repaired soon. (Unplug until repaired.) This can cause a weakened internal overload inside the compressor. Thanks, Sea Breeze
Sep 21, 2009 | Refrigerators
Need location of defrost timer
The refrigerator you listed does not have a defrost timer. All defrost and refrigerator functions are controlled on rear of the refrigerator. It's called a mother board. If it s damaged you will sometimes see burns on one of the both sides, but not always. Another problem could be that your defrost element or defrost thermostat is defective. You can see your refrigerator below by putting the model GSS201EMBWW into the model search feature. I am here to help you if you want, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Here is another link here on FixYa that shows the mother board
http://www.fixya.com/support/t230703-ge_refrigerator_stopped_working
May 28, 2009 | GE GSS25SGMBS Side by Side Refrigerator
GSS22WGPAWW side-by-side. No cooling at all
Sounds like the compressor has stopped working. Replacement would be necessary.
Feb 23, 2009 | GE Refrigerators
hi. thanks for the question . its 3.75 oz. if it runs for a while and ices up. the problem is in the defrost cycle .look at the defrost timer, and defrost termination switch ,in freezer thanks. the appliance doc
Oct 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge "runs" constantly
unit should shut off when temperature reached ie compressor and fan stop.
condensor is just a grid of pipework
heater only comes on when in defrost cycle
Jul 12, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
