Question about Marantz Audio Players & Recorders
Won't turn on.
Is there a fuse inside the unit?
    Novelist:
    Champion:
  • 225 Answers
Yes BUT there is also high voltages both with and WITHOUT the unit connected to an A.C. plug. If you decide to check fuses, and you find one that is blown, PLEASE use ONLY the original value fuse.
Posted on Nov 02, 2012
Sony Blue Ray Player BDP S 390 won't turn on
About the only easy chance is follow the power cord inside the unit and look for the fuse.
Dec 03, 2012 | Televison & Video
Won't turn on
If no power light etc look for a fuse---follow the cord inside with unit unplugged-----?
Nov 04, 2012 | JVC XV-BP1 Blu-Ray Player
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
Tv won't turn on like it's unplugged but it's not
I have seen the same problem with my tv's and the like. Depending on the age of the unit, I could sometimes find a blown fuse inside (safety feature). Many electronics especially tv's are extremely fussy about power surges. Even times when I knew there was no power surge, I would find a blown fuse inside the unit, keeping power from ever reaching it's destination. Like you said. tv behaving like its off because no power getting through
Mar 25, 2012 | Fusion FUS37LCR 37 LCD TV
Fuse
Hello!
Why do you want to replace fuse? Is your projector dead? In many cases just a fuse replacement will not solve the problem. if fuse is blown, good chance, that power supply has shorted components. still, you may try to replace the fuse with lower grade, first, and observe the behavior. If unit turns on and starts operate normally, then fuse blows, you may install the stock fuse. Means: it's just a fuse's issue. If it blows right away, don't even try to put regular fuse, instead. unit must be repaired, first. Power supply or ballast might be shorted. To locate a fuse, you must look around the unit and find a little door, says: fuse. it might have a screw or two holding it, might not. Look at the fuse, first: if it looks pulverized, don't even dare to replace it! it will blow again and make more damage to the unit. If thin wire inside is just torn, then follow the procedure, described above. If the fuse is ceramic, you won't be able to determine, how it blew. Look at the fuse's rating: it might be written on a fuse door, or on the fuse, itself. could be from 5amp to 10amp, depend on power consumption. Remember: first, install the fuse with 1/2 of value: i.e: 6amp-put 3amp first, etc. Good luck with your project.
Thanks,
Alex.
Jan 07, 2012 | Panasonic PTAE2000U LCD Projector
Where are the fuses in the harman kardon 3380 receiver, I had a lightning strike which I think knocked out my receiver thru my outdoor speakers, it will not turn on, could it be a fuse and if yes, where is...
Hello Randy,
There are two options here: first, the power button is amber but unit still won't go. In this case try a 'factory reset' as per manual. If this won't work, it seems that the processor is gone (located on the display board) so you have to bring your unit into a authorized shop for repairs. Secondly, it might be just matter of some blown fuses which are located inside the unit on the transformer board. If after replacing (if they're blown) the unit still won't work or keeps blowing the new fuses, follow the first advice, meaning you have to bring the receiver to a service. To access the fuses, you have to remove the top cover.I wish you luck
Kostiko
Sep 12, 2011 | Harman Kardon HK 3380 Receiver
2007 azera cd won't play & willnot eject or load cd's
Odds are the electronics inside the audio unit (head) have malfunctioned. There is only one way to check/verify this. The passenger compartment Fuse/Relay box has a power bar (shunt fuse) yellow in color. Pull this fuse out (not all the way out). Wait 60 seconds then reinsert (push back in) to reset the Audio (Radio) unit. Recheck the CD functions (load/eject). If the same problem recurs, then it's the audio unit/head which has malfunctioned. The typical repair is replace the audio unit.
Sep 10, 2011 | 2006 Hyundai Azera
Cuisanart 10 c programmable coffeemaker won't work; no light comes on & it is plugged in. It has been working fine.
Check it's fuse inside, a blown or open fuse will cause won't work. Similar also happened if the cord wire is already open. Same goes also if the power switch is already defective. Either of those I mentioned will cause the unit not to work.
Thanks for asking.
Jun 25, 2011 | Vacuums
Outside unit won't come on. Drain pas appears dry/.
if nothing comes on (on the outside unit) when you turn on AC (and the inside unit runs ok) I would check the fuses and/or the breaker for the outside unit. I would suspect a fuse blown or a breaker tripped. It's also possible that your 'low voltage' (24V) thermostat wire has been cut (by lawn mower) or chewed into (by dog). If the problem is the low voltage wire you can easily splice it back together - just be sure all power is off.
Jun 06, 2011 | Goodman CKL36AR36 Air Conditioner
The air conditioning unit won't work. The lights behind the panel light up, and when I turn the air all the way to cold, you can hear a click like it wants to go on, but can't. Do you know how to...
Check the fuse block. Sounds like the compressor fuse is blown. Maybe a 32Amp. It's a biggie. Maybe looks like a black relay in the engine compartment on the left side along with an array of large fuses. You can check the fuse box inside the car as well, but those are controlling smaller items like lights. The big boys are in the engine compartment. Also check for loose wires around the AC compressor and make sure the belt is not broken or missing.
May 25, 2011 | 2004 Saab 9-3
632 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
