Question about Nokia C5-00
Nokia c5-00 2 unplage power supply save energy solutions not charging
Nokia c5-00 2 (noy charging) sowing unplage power supply save energy solution
We are a NGO in Guinea where there is no electricity. We are working with a generator to power our fridge. My question is if we can connect an energie station to the generator to charge it and then later...
well i guess it ok to use or connect energy station..but you need a higher battery to use.because we are talking fridge here..i think number of batteries you need for long life of the energy station..i suggest why trying solar energy to save much fuel..i hope it helps..
Jul 21, 2011 | Monster Cable Monster Mobile PowerStation...
Need to confirm how to properly connect the computer cables to a Belkin Outlet Surgemaster Energy Saving Surge Protector (e.g. laptop power cord in the "Master slot" and the Dell monitor display...
Sounds like you got it right. When the Laptop draws power it will trigger the Surgemaster to turn on the monitor. The only problem you might have, is being you are using a laptop the power supply might not draw enough power to trigger the energy saving features.
These devices work the best when a tower PC is plugged into the Master slot.
Chris
May 20, 2011 | Computers & Internet
Lg rd 3500 show charging on display but power not save , what i do?
lg rd 3500 show charging on display but not charging.....plz solution
Dec 08, 2010 | Welding Tools
My nokia N72 is writing not charging.what do i do
hello,it's either you are having a bad charging port or a bad battery,so i will advice you get another battery to test it if it will charge,but if it doesn't then you will have to change the charging port.
you can as well check if the current voltage of your power supply is not below the usual or supposed supply.
please kindly rate the solution if it's helpful,
take care.
Jun 09, 2010 | Nokia N72 Cellular Phone
6630 phone charging but not charge full charging simple is 2point
my nokia 6630 is sow charging but batry is not charging
Apr 22, 2010 | Nokia 6630 Handheld
Screen is dull while on ac power. When running on battery screen brightens up but battery does not last long. Power supply is supplying 19.17 volts which but on the power supply is written 18.5 volts.
ery adjusting your brightness via the function keys on the keyboard also under power settings see if screen is set to save energy when using ac power usually this is set to save power when on batteries it just might be reversed on your machine
Dec 12, 2009 | HP Compaq nx9110 Notebook
When a plug the charging pin into nokia 2300 the display is not charging (any solution)
i have a nokia 2300 when charger is plug in it dis plays not charging
Jul 14, 2009 | Nokia 2300 Cellular Phone
Phone will not turn on
sir please check with your battry
Jun 07, 2009 | Nokia 6500 Slide Cellular Phone
New LG 2452T keeps going to digital power saving mode
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
Feb 28, 2009 | LG Flatron L2320A 23" LCD Monitor
Power Up Problem
Contact Service Center (Nokia Care).
Sahaja Yoga is the Mahaa Yoga and is FREE OF CHARGE.
Sahaja Yoga is the Only Solution to all the Problems of World and is the Only Way to Save the World.
Apr 03, 2008 | Nokia 6300 Cellular Phone
Nokia C5-00 Logo
662 people viewed this question
Top Nokia Audio Players & Recorders Experts
Vernon Taylor
ray gallant
Outback Jack
Outback Jack
Are you a Nokia Audio Player and Recorder Expert? Answer questions, earn points and help others
