Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer will not work at all
There is power, but no response from the panel
  • Lori Price Jan 06, 2009
    I think I have the same problem...all the buttons work as far as setting the time for drying, etc. but when press the start button, it pings and nothing happens....help!
    Problem Solver:
I just finished changing the thermal fuse on my dryer, model MDE5500AYW, and it solved my problem. The thermal fuses can be purchased at any appliance part store...and cost me $4.
Posted on Jan 08, 2009
Our dryer does not function after a slight power outage due to an electrical storm. The number 88 blinks for a minute then goes to 18 . There is no response to the control panel , no buttons work!
brand and model numbers would be very helpful. without this info, I would try unplugging, wait about a minute, then plug back in. sometimes units can be reset by just cycling the power. Good luck.
Aug 05, 2017 | Dryers
Maytag lse 1000
Could be
I replaced the control panel on my
Maytag & it wasn't a year old
If you tip the machine over & look up high
inside the outer shell,you will find a bag taped
under there with the diagnostic manual,at least
I did
You will have to clearly understand what it says
& I had to back probe the circuit board, as you would
working on a car, to take the voltage readings,live
If you don't have those skills, your in trouble
Have to know basic wiring diagrams
Sep 06, 2013 | Washing Machines
Control Panel is on but no response to buttons being pushed. Recycled power - no help
Have been having the same problem on and off for about 9 months now. It would unfreeze quickly at first by heating the top of the dryer cabinet at the control panel with a hair dryer (believe it or not). Got tired of doing that every time I need to use the dryer so just ordered a new control assembly with touchpad. Here's the link: http://www.appliancepartspros.com/part_details.aspx?part_id=4043476
Good luck
Nov 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
Dryer quit working. Completely dead
Hi, If this is a whirlpool model dryer, try this: Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If this is another brand dryer, please let me know the model # so I can assist yyou further.
Thanks
Vic
May 30, 2009 | Dryers
Whirlpool Duet Dryer not working
I would say youwould save money by having a technician from a reputable company come and check the unit. you could have multiple problems from what you did when it was wired wrong.
May 28, 2009 | Whirlpool GEW9250P Electric Dryer
Fisher and Paykel (NZ) tumbler dryer
Try switching off the power to the machine for 5-15 mins and then re-switch power on
Had same symptoms with my multi-temp F&P front load dryer.
Andy
Nov 30, 2007 | Fisher and Paykel DEGX1 Electric Dryer
No pwer in Control panel but light is on the the dryer
You may have blown one of the two circuit breakers at the building fuse box. Sometimes they are physically linked together so that both trip at the same time. This is how it's suppose to work but sometimes one will trip leaving you with half power but enough to work the minor circuits. Resetting the circuit breaker is an easy fix. If this doesn't work ohm out the thermal fuses. They are ususally accessable by lifting the top. With it open check that all connector are connected.
Jun 13, 2007 | Frigidaire FEQ1442ES Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
232 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
