Question about Clarke Air Tools & Compressors
Failed capacitor on clarke SE 14 compessor
My cousin has a Clarke se14 AB compessor that I am trying to repair for him. One of the capacitors blown on the motor. The motor is fitted with two capacitors the OK one is marked 220uF but the blown one had been painted over and when the paint was removed by my cousin he also removed the value markings any one know what the second cap value should be? I have emailed clarke but no reply.
  • 885 Answers
On electric motors with two capacitors, one is a start capacitor, the other is a run capacitor. Start capicitors have plastic cases and are rated from 200mf to 400mf and higher depending on the size of the motor. Run capacitors are in the 20mf to 40mf range and usually have metal cases. If you have an electric motor service center in the area they can recommend what size you should use for the size (HP) motor you have.
Posted on Nov 02, 2012
5 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: My dad bought a used 2HP 4 gallon clarke pancake
hi there!
some motor compressor are equipted of centrifugal switch connected at the shatfting of the motor compressor after turning at rated speed this will be open and disconnecting your starting circuit as well as the starting capacitor.
have anice day fix my rate, thank you
Posted on May 08, 2010
  • 8404 Answers
SOURCE: Blown capacitor
Radio Shack ... Jonestone Supply ... FixYa.com advertiser ... any place that services electric motors.
Thanks for your interest in FixYa.com
Posted on May 26, 2010
  • 1274 Answers
SOURCE: Where can I but a replacement Capacitor for the
Hi, my name is John. Welcome to FixYa. You can get it here www.mastertoolrepair.com .Thanks for choosing FixYa...John
Posted on Nov 27, 2010
  • 2468 Answers
SOURCE: I have a Clarke 2000B
take it back to the store where purchased with the sales slip and exchange it,if not possible,then clarke is made by ingersol-rand corp. call them
Posted on Jan 27, 2011
Where can i buy a capacitor part# FN009200004
Get a hold of an electric motor repair shop. They can likely get you one.
Nov 03, 2015 | Clarke Power Products Inc AC2000 2HP 6...
AIR COMPESSOR MOTOR SLOWS DOWN
capacitor problem not splitting phase sufficently
Nov 04, 2013 | Clarke Power Products Inc AC2001 2HP 4...
I have a 100e clarke the wire speed board went bad feeds fast all the time where can I get 1
It is likely the SCR's failed. It is much cheaper to replace those than the entire board. Also look for bulging electrolytic capacitors as they would indicate a shorted condition as well.
Jan 11, 2012 | Clarke Power Products Welding Tools
I need a huizhong cbb60 120uf capcitor for clark air compressor
You can use any brand motor run capacitor for this application (metal can). Mfd rating should be within plus or minus 5 percent of what you need (about 110 to 125uf). You can also use two 60 mfd motor run capacitors. Voltage rating should the same or higher ( higher voltage rating, better quality). Capacitors fail when there are too many start cycles per hour and or low power to comperssor. Generators also tend to shorten the life of caps due to low power at start and variance of cycles. Good luck with your repair.
Sep 21, 2011 | Clarke Power Products Inc AC2001 2HP 4...
Need on off switch for clark chopsaw 14" BT1010B
The part number for this switch is BT1010B-74. (per manual)
You will need to contact Clarke here:
http://www.clarkeservice.co.uk/parts.shtml
or email them here:
info@clarkeinternational.com / service@clarkeinternational.com
They do not have on line parts info.
Thanks for choosing FixYa,
Kelly
May 07, 2011 | Clarke Power Products Clarke 6" Abrasive...
Where can I but a replacement Capacitor for the Clarke AC2001 Air Compressor
Nov 20, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Blown capacitor
May 26, 2010 | Clarke Power Products Inc AC2001 2HP 4...
My dad bought a used 2HP 4 gallon clarke pancake type air compressor at an auction. It keeps blowing capacitors. Does it have a centrifical switch to take the cap out of the cct once started?
hi there!
May 07, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Air Tools & Compressors Logo
225 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
