Question about Zanussi Washing Machines
Zanussi washing machine fe1404
Beeping
  • 1294 Answers
SOURCE: Zanussi err problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
SOURCE: Zanussi ZWF16581W Washing Machine
Not helpful as the instructions given in the manual do not work. It may be that they do work at a certain point but they don't tell you WHEN to press them. When the machine has irritated you beyond belief in beeping like a maniac? Before you start the cycle? during the cycle? When? Have tried all of these but to no avail. What am I missing?!
Posted on Aug 04, 2009
SOURCE: Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Posted on Mar 14, 2010
SOURCE: Zanussi washing machine is making five beeps
My Zanussi Fs1555w is not finishing it's cycle and beeping 7 times. If I put on spin the cycle lasts less than a minute before the end button beeps, then it will beep repetitively 7 times until turned off. Please help
Posted on Jun 03, 2010
My zanussi zwx1605w was washing then just stopped working.
zanussi zwx1605w. i have lost my manuel and cant washing machine to start?
Mar 26, 2010 | Zanussi ZWF1650W Front Load Washer
Zanussi washing machine is making five beeps and not workign - what does this mean? It is not in the manual
Feb 05, 2010 | Zanussi FS1455W Front Load Washer
Wahing machine
Try pushing the skip button this may reset the prog. These machines will beep to indicate a fault. Dependant on how many times the machine beeps b4 it pauses ie 1 beep then a pause would indicate the machine isn't filling, 2 beeps its not pumping out, 4 beeps doors open. Hope this helps
Nov 30, 2008 | Zanussi FJS1225W Front Load Washer
My zanussi will not turn on at all.
If you give the facia a tap the display may come back on. You may then get an error code E90 being displayed. Either way you will require a new user interface pcb.
Nov 18, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1500 only beeps on the end function when i switch it?
does the machine spin properly i know on most zanussi's if the pump is blocked it will either beep or not do any thing there should be an out let at the bottom right of the machine.try that
Aug 02, 2008 | Washing Machines
Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
