Question about Electrolux Washing Machines
Machine not running and macke error e35 - Electrolux Washing Machines
  • 3 Answers
Maybe your washing machine is not been used for a year sodeal with a specialist
Posted on Oct 31, 2012
Where do I find the serial number on my sole e35 elliptical? Thanks !
E35 - Copied from E25 answer - on the front of the machine, right under the display, on the back side, there is a pyramid shaped piece of plastic wrapped around the middle bar. Pry it up with a screwdriver (if needed but it should slide), it should unsnap, and will reveal the mythical red serial number. And it should also be on the warranty registration card.
Sep 21, 2015 | Sole Fitness Sole E35 Elliptical
I have a Electrolux front loader and im getting an error code of e35 what does this mean
Signals washer has overfilled, pressure hose or pressure switch most likely
Dec 25, 2014 | Electrolux Washing Machines
I have Electrolux front load wahser Model EIFLW55HIW0 that is about 6 years old, Has worked without a problem for many years. recently started giving E35 error codes. the water doesn't ap
Hello friend, thank you very much for your inquiry!
After reviewing the information you have provided regarding your Electrolux front load washer EIFLW55HIW0 having an E35 error code, I have found E35 is an indication of a water over fill problem. If the water fills above 4.5 inches please follow the below trouble shooting steps I have provided for you. If the water is not above 4.5 inches you may need to change the pressure sensor switch.
If the water enters continuously please unplug the washer to see if the water stops. If the water does not stop your issue may be the water valve assembly. If the water does stop the wiring to the water valve assembly needs to be checked. If the wiring is good the control board may need to be replaced.
I do suggest you seek a professional technician to look into this issue further to avoid any unnecessary part purchases. - T
Sep 28, 2014 | Electrolux Washing Machines
Error code E35 what is this?
switch off the elec remove lid and check the pressure switch tubing is not been rubbing against the side of the mach and wearing a tiny hole into the tubing .there is sometimes 2 tubes looking from the rear of the mach they are at the left handside not the best place i normally take the rear half of the mach off to gain access .also it only needs apin hole or less to cause bother take care hope this helps
May 06, 2014 | Washing Machines
E35 error code
chec the drain pump, if there is a coin blockingthe whole
Nov 02, 2012 | Electrolux EIFLW55HIW Front Load Washer...
What is the reset code of toshiba estudio 181
i have toshiba e studio 181 it gives an error of paper size its not accepting any paper size expect A3 size plzz help how to set paper size
Sep 12, 2012 | Toshiba e-STUDIO181
Washing Machines Logo
280 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
