Question about Sharp 27H-S60 TV
Screen changes from normal to green instantly
My Sharp 27Hs60 will change from a green tinted screen, then back again in an instant. I know that it may be that the tube is going, but if that were true wouldnt it change and stay that way? If I press the volume it changes, or change channels it changes, then wil pop back again depending what is on the screen. Help? Andrew
Sharp27h-s60 has sound no pitcure with horiznal line
Posted on Feb 05, 2008
    Genius:
  • 1,074 Answers
Intermittent problem resolder around the color circuit.good luck.
Posted on May 18, 2007
SOURCE:
Software problems. Digital games won't load
Perform a hard restart, hold the power button for 10 seconds while the system is on. The system will turn off. When you hit the button again, it will start and display the green start-up screen.
All your data is preserved, but cache is cleared and some settings are reverted and log-in or game start issues are resolved.
Alternatively, you can perform a full shutdown by going to SETTINGS / POWER & STARTUP and change POWER MODE from Instant-On to Energy-saving. After changing the setting, choose "Turn Xbox off". It can be powered back on by holding down the GUIDE button on the Xbox controller or the button on the front of the Xbox console. Once it's back online you can go back to SETTINGS / POWER & STARTUP and re-enable Instant-on.
Sep 22, 2018 | Games Video Game Consoles & Games
My tv has a red tint to it not sure what to do?
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 17, 2013 | Philips Televison & Video
My flat screen hd sharp aquos color turns green when we are watching it. it is only 3 three years old. what can this be? thanks
I'm not sure if this is the same, but people were green no matter how i adjusted the tint, and lacked overall color. I doubled checked the component cables, taking each one out, and putting it back firmly,
Picture is back to normal. Easy fix.
Feb 10, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Image streched when in full screen 1980x1200 format.
I changed the D-sub cable for a DVI one and the problem was instantly solved.
Apr 14, 2009 | BenQ FP231W 23" LCD Monitor
Monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
Green line
sharp is very aware of the panel and main video processor problems.They should give you no problems on the repair.It sounds most likely you have a main video processor problem.
Mar 13, 2008 | Televison & Video
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Televison & Video Logo
111 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
