Question about Echo Garden
Echo 770 blower leaks fuel out of grommet - Echo Garden
4 Suggested Answers
  • 279 Answers
SOURCE: gas is leaking from the leaf blower.
Unless the tank has been cracked, it has to be one of the following: Broken lines, split primer bulb, unsealed fuel cap, bowl gasket of carb. I would start with the lines and bulb since they are the ones usually at fault..Good luck...Lee
Posted on Sep 04, 2009
  • 51 Answers
SOURCE: Echo leaf blower will not start....leaks fuel from
sounds like u have a carb problem,ether theres debris stuck in needle valve needle is stuck open or the check valve diaphram is bad.take carb off on one side there is a plate with 4 screws remove then agasket and diaphram remove them some times they stick to carb so use a razor blade to go underneth diaphram all around from center youll see a metal see saw with a pin going through if u push on center it will lift needle valve on other side make sure it goes all the way down or remove by removing screw that holds pin in and blow out with air lightly may blow seat out after that on other side of carb take other plate off by center screw that diaphram has 2 little flaps check valves make sure they are limber and not wrinkled or bent if so u can get new ones at good mower shop or parts supply hope this helps
Posted on Aug 08, 2010
  • 30 Answers
SOURCE: Primer bulb will not remain full. Blower will
you should maybe change grommets/pipes to the fuel tank,also the primer bulb maybe is not working properly,consider changing the primer bulb,rgds
Posted on Sep 25, 2010
My echo pb-251 leaf blower won't start and sounds like a slight backfire - what is the likely cause?
Consider the flywheel. This model uses a flywheel with a built in key. If that key is bent or broken the timing would be off which would explain the backfire. You can source a replacement unit from eReplacement parts. Unfortunately the flywheel is 44 bucks and you have to be able to dismantle the unit to replace it. These blowers cost 200 dollars new. So you have a little wiggle room here. If the flywheel is good you may have a bad coil which can cause timing problems or weak spark. But those are 76 bucks so look at the flywheel first.
Jul 01, 2014 | Echo Gas Blower 135 MPH390 CFM Blower...
Echo 770t misfiring
I have installed new carb kit, fuel lines, plug, and air filter. Blower continues to bogg down when opening up throttle. echo 770 blower any ideas?
Aug 13, 2013 | Echo Backpack Blower PB-770T
Gas leaking from grommet that goes into the gas tank.model pb-2111.
replace grommet. you may want to replace the fuel lines to you can use echo part number # 90098. its a fuel line kit and it come with all fuel lines, grommet, fuel filter, and vent. its plug and play.
Sep 21, 2011 | Echo Garden
My Echo PB-251 leaks gas out the exhaust when stored, becomes flooded and hard to start.
well 1st thing with the amount of alcohol that's in gas now days it's no longer a safe/good idea to store even for short time power tools with fuel in them , second are u sure its coming from exhaust or maybe near there ? reason I ask is that maybe there's a fuel hose that's leaking and it runs out near there , this needs attention as fuel could continue to leak out when tool is in operation as well , leaking hoses are a very common problem in todays power tools , from a 600 hundred dollar huskavarnia to a 40 dollar echo none of them make fuel hose they all buy them (probably from same place)
Aug 30, 2011 | ECHO, Inc. PB-251C Handheld Blower
Only runs upside down. When right side up it acts like it runs out of gas
Sounds like fuel line problem. Empty fuel tank,remove black fuel line grommet,check for line break or disconnection.If line is broken , purchase fuel line kit with grommet as a set if lines or grommet are deteriorated.
Aug 29, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
My Echo Leaf Blower (PB-251) will not run at high speed. It is running to rich. Help please. Charlie
I've been fighting with an Echo PB-251 blower and an Echo SRM-225 string trimmer since near the end of last lawn season (this is the forth season I've had them). Along comes a thread on a firearms forum and lo and behold the answer to the problem is spelled out in terms even I can understand.
After reading that thread (which attributes the problem of the engine bogging down when throttle is activated to collapsing fuel lines) I was going to just replace the fuel lines, but I discovered that there are kits that include new fuel lines, rubber grommets, filters, clips and cap seals for about $13.00 each. Hell, the kit for the SRM-225 even provided a new primer bulb. Ten minutes after the UPS truck delivered them to my door I had both machines running like new again. If you've tried other things and it still hasn't worked I highly suggest you try this.
Jan 05, 2011 | ECHO, Inc. PB-251C Handheld Blower
Grommet on top of fuel tank leak. where can i buy one
There is one here for a low price...but the shipping may be high. Check on Ebay also.
http://www.partstree.com/parts/?lc=echo&mn=SRM-210++S%2FN%3A+S65311001001+-+S65311999999&dn=8336
At least now you have the part number and any decent small engine shop could order one for you.
Nov 10, 2010 | Echo Garden
Primer bulb will not remain full. Blower will start but dies when throttle is used. Appears to be leaking air around the grommet to the fuel tank.
Sep 25, 2010 | Echo Garden
Echo shred n vac starts,idles, runs to about half power then bogs
Check the grommet that sits on top of tank where lines from go carb. Grommet may be rotten and crack. Try that. Have you ever replace the carb repair kit? The diaphram may be torn, defoam or have holes in them. Carb kit cost arount $10, but don't mess with the welch plug or screen in carb.
Feb 16, 2010 | ECHO, Inc. Shred n Vac
Gas is leaking from the leaf blower.
Sep 04, 2009 | Echo Garden
Garden Logo
41 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
