Question about Kodak Cameras
Kodak easyshare max z990 joystick will not return to zoom out automaticly when i realease the joystick i have to stop it manualy zoom in works as normal when im zoomin and let go it stops
    Genius:
  • Kodak Master
  • 1,019 Answers
Switch malfunction, needs repair.
Posted on Jan 24, 2013
SOURCE: kodak easyshare z1275 not working =(
PROBLEM - Camera will not turn on at all regardless of battery used. Happened after about 8 months of use. Kodak instructed me to send the camera in of warranty repair. MCU was replaced. The unfortunate thing is that I have the same problem again, 7 months later and I am guessing it is not a warranty repair this time.
Posted on Feb 24, 2009
  • 5 Answers
SOURCE: Zoom Problem with Kodak V603 PLEASE HELP
ok i fixed mine by spitting on the battery contacts and wiping it off on the inside of my shirt...so it basically just needs to be cleaned-but make sure you dry it afterwards or the battery might break or leak
Posted on Aug 11, 2009
  • 32 Answers
SOURCE: Kodak Easyshare Software has stopped working
Close Easyshare Program > If you see an icon of easyshare at the system tray {lower right corner of the screen}
right click on it and choose Shutdown Easyshare
Right Click on the icon of Easyshare on your desktop{upper left of screen}
choose Properties, choose Open file location> Look for Catalog Folder > rename it to "old catalog" > close the whole window
Go to My Computer > C: Drive > Users > Public > Public Documents >
Look for ESBK.mb and ESBK.mbb
restart your computer
Relaunch Easyshare Program
Goodluck...
Posted on Sep 23, 2009
leepania
  • 1099 Answers
SOURCE: Kodak EasyShare C653 Camera, cannot connect to my macbook
Try a dig. USB plug,
Try a dif. cable.
Try with a cardreader.
If your cable is faulty it is covered under the same 1 year warranty as the cam.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 03, 2009
SOURCE: Grey cradle that surrounds the joystick is jammed?
Have you found a solution to this? My camera has the same problem.
Posted on Jan 19, 2010
Started birding, what settings bestr on my camera
Briefly, I would suggest telephoto end of zoom, high shutter speed and support of some sort (monopod / tripod). Be prepared for quite a large number of unsuccessful shots ! Good luck.
Jan 13, 2016 | Kodak EasyShare Max Z990 12.0 MP Digital...
Z990 with USB from computer to camera will not transfer pictures to Kodak easyshare
there is at least 3 way to transfer pictures from camera. this video explains all three.
Dec 16, 2012 | Kodak Easyshare Max Camera Z990 Digital...
I HAVE A KODAK MAX Z990.I LOST THE ABILITY TO DOWNLOAD MY PICTURES. I LOST THE PROGRAM ON MY COMPUTER.
Hello Tom, Sounds like all you need to do is a fresh reinstall of the software and everything should be fine. This is a normal problem with Microsoft Windows.
Nov 24, 2012 | Kodak Easyshare Max Camera Z990 Digital...
Trying to download pictures to my computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 24, 2012 | Kodak Easyshare Max Z990 12mp 30x...
After I take a picture sometimes it takes quite a while until I can take another picture. I hold the button about half way down but that doesn't work.
1) clean the main switch for dirty, corrosion, with c. cleaner
2) test the switch for defective, use VOM for continuity and replace if necessary
3) use batteries for same type alkaline Ultra Heavy duty,
4) see if are the o.k direction.
5) clean the contacts batteries with c. cleaner
Oct 17, 2012 | Kodak Easyshare Max Z990 12mp 30x...
I have a Kodak Z990 easy share camera and memory card is protected came up and said reset switch on memory card. How do I reset memory card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 06, 2012 | Kodak Easyshare Max Z990 12mp 30x...
My Kodak z990 has a memory card is protected and reset switch on memory card. How do I reset memory card
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 06, 2012 | Kodak Easyshare Max Camera Z990 Digital...
My joystick only work up down and right
I had the same problem. I took my Z760 apart and put in a joystick from a used Z760. But the problem is that the joystick comes unglued from the small computer board. Take it apart and put a tiny drop of superglue on the joystick. Use a magnifier to line up the two little tabs in the proper holes. It should work fine.
Jul 10, 2008 | Kodak EasyShare Z760 Digital Camera
Cameras Logo
56 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
