Question about Pelonis Disc Furnace Heater
Don't Light a Cigarette around the B2-IVA Disc Heater
I had it sitting on floor near my desk. I quickly lit a cigarette using a long nose lighte. A fine line of flame connected from the heater to my sweater and caught my sweater on fire!
Totally nuts! Scary.
3 Suggested Answers
SOURCE: caution light comes on,rarely used heater. any thoughts?
Try calling 1-866-876-4332 ext 224 for tech help, it worked for me.  I only needed a temp
setting/off switch to fix mine.
Posted on Oct 23, 2008
mkh5094
  • 145 Answers
SOURCE: Pelonis LT101A/ B2-IVA
Pelonis heaters generally have safety devices built in to them for if they fall over and such. This model may have other safety devices, I would check it out in the manual. If its completely dead in the camper, there could be a problem with the outlet in the camper.
Posted on Apr 27, 2010
How do I remove the cigarette lighter in my Tracer. It is really hard to reach the back of it.
I don't know what year it is. But this video from youtube may give you an idea of how to do yours. You can buy electrical tape & a cheap screwdriver & needle nose pliers at Walmart. Wrap the screwdriver tip so you don't scratch your plastic like this guy did in the video. Use the needle nose to unscrew the nut, if there is one. The replacement lighters show just a Blade type; 1-prong male terminal. Have you tried just prying it out near the rim of the lighter? https://www.youtube.com/watch?v=CmwXCBo2M9k&list=TL22RiG_zP4oVIBeL9_yKdcKytU23ZZ3o0
Sep 29, 2016 | Mercury Tracer Cars & Trucks
1997 lighter socket stopped working
You have to find the fuse for it, check the fuse, and if OK, then you have to check for power and ground at the socket to find the problem. Youtube probably has a video how to use a voltmeter or test light to check for power and ground.
Those cigarette lighters almost never used to fail. Good for years and years. But now with all the devices people can stick in them, they have problems pretty frequently. Maybe an overload in some cases.
Mar 20, 2016 | Cars & Trucks
Was driving with tandem trailer on cruze controll all of sudden I lost acceleration peddle went to floor I turned cruzecontroll off and power came bck but seemed like was miss firing
Most cruise control is vacuum controlled. I would suspect a vacuum leak. Try placing a lit cigarette around cruise control module looking for smoke drawn towards leak
Feb 15, 2015 | Cars & Trucks
Can someone tell me where i can locate cigarette lighter fuse in a toyota funcargo ncp20, i located 2 fuse boxes, 1 under the steering wheel, and other under the hood but on covers don't show a sign of...
put your low lights on,see if sigaret lighter lids up.
box under steeringwheel.take out one by one and see whit fuse,
light goes off.is also possible in the cover off the box is indicated whits one it is
Jul 07, 2013 | Cars & Trucks
2001 Montero Sport cigarette lighter interior light will not turn off
No its not normal and yes that could drain the battery.
I would think the light around the ignition key lock would be on too.
Probably a courtesy light problem - there is a timer somewhere that turns those lights off after you close the doors.
If it is just the light for the lighter you could cut that wire.
Jun 29, 2012 | 2001 Mitsubishi Montero Sport 4WD
Lighter dont work a dime went in there
You have to get the dime out of there since it's metal and shorting out the lighter contacts.
Feb 24, 2011 | Mercedes-Benz CLS500 Cars & Trucks
How to installation ? what the Accessories ? thanx
accessories is usually the first position of your ignition key when you turn key from off. no ignition lights should be lit and cigarette lighter should work. this is acc circuit.you need to connect acc wire of head unit to this circuit. (can pick it up at cigarette lighter ) but if your looking to wire REM wire to acc ---DON"T--- wire it to the blue wire on back of head unit(rem out)or blue with white stripe.
Jun 16, 2010 | Infinity Reference 7541a Car Audio...
Range Rover p38 we have just fitted a new battery and now the heater wont come on or light up, nor does the cigarette lighter or the stereo
check the fuse first ,look up cigarette lighter fuses first i bet that is blown ,cos that fuse is part of cigertte lighter and ur stereo aas well also check ur heater fuses as well
Nov 19, 2009 | 1997 Land Rover Range Rover
Pelonis Disc Furnace Heater Logo
43 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
