Question about Electrical Supplies
Need instruction manual help to install a TL21 intermatic 24 hr time switch
  • 5,245 Answers
Copy following links to identify timer, and replacement parts, and see wiring illustration:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-WH21-timer.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#wh
Recommend heavier duty timer, like WH40, if water heater elements, or load, is greater than 4500 watts.
Posted on Nov 01, 2012
5 Suggested Answers
  • 18 Answers
SOURCE: instructions on how to program the Intermatic EJ351C
take a look at this :
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
-or -
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
hope this helps
Posted on Jun 08, 2009
  • 101 Answers
SOURCE: I have the Intermatic T101 24 Hr. The light come
Does the clock stop, or does the light just stay on? Without knowing any further information, you have a tripper that is set for the time to go on...now, you should have one that is set to go off. Make sure you have both trippers set, and working. (ie. set one to go ON at 8:00 pm, and the other to go off at 8:30 pm). If so, then set them to your desired times - and try again.  Also, I'm not sure how long you've had this timer - because you could have a bad motor. If so, it's cheaper to buy a new timer - than try and buy a motor for it. Anyway, try the above information I gave you - and then let me know what happens. Any other information you can give me would be great. I hope the above info. helps you, but if not - we'll try Plan B. Good Luck! - JR
Posted on Jul 06, 2010
SOURCE: my Intermatic T101-24 Hr.Dial Timer Switch is turn
Open following link for troubleshoot checklist
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Posted on Jun 28, 2011
SOURCE: T101 - 24 Hr. Dial Time Switch - NEMA 1 Indoor Steel Case - Gray: With my Intermatic T102, the manual on/off switch ...
Intermatic timer instructions
http://www.intermatic.com/~/media/Intermatic/Documentation/Time%20Switches/Mechanical%20Time%20Switches/24%20Hour/T100%20Series/T101%20Instructions.ashx
Aug 01, 2014 | Intermatic T101 - 24 Hr. Dial Time Switch...
How do i program the above timer?
Here are the instructions:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t101%20-%20english.ashx
Basically, pull the yellow dial out, rotate the yellow dial until the pointer indicates the current time, then push the dial back in. Set the ON/OFF trippers as desired.
Feb 06, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
Just installed a T101. Unit will not switch to on position works perfectly to off position. Can it be adjusted.
Yes.
Programming Instructions for the Intermatic T101 - 24 Hr. Dial Time Switch:
1. TO SET ON AND OFF TIMES: Hold trippers agains edge of clock-dial, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A.
2. TO SET TIME-OF-DAY: Pull CLOCK-DIAL outward. Turn in either direction and align the exact time-of-day on the CLOCK-DIAL (the time now, when switch is being put into operation) to the pointer. DO NOT MOVE POINTER.
Operating Instructions:
* To operate switch manually: move manual lever below clock-dial left or right as indicate by arrows (graphics) This will not efect next operation.
* In case of power failure, reset clock-dial to proper time-of-day. See Programing Instructions (top lines).
Good luck (reemmber rated this help).
Oct 23, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Instructions on how to program the Intermatic EJ351C
-or -
hope this helps
Jun 03, 2009 | Intermatic Programmable 24 Wall Switch...
Electrical Supplies Logo
156 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
