Question about Scotsman Refrigerators
Scotsman DCE33A-1WB not draining
Machine is making ice bot there is about 3 inches of water at the bottom of the machine.
  • 27 Answers
Check that Ice cubes are freeezing completely before dumping into tray.
Check that spray nozzle isn't inadverdantly clogged and spraying water everywhere.
Check that water inlet solenoid is actually closing and not leaking water into bin.
Check thermostat for the bin not working properly, frozen over or something.
Posted on Oct 31, 2012
  • John Boujoulian Oct 31, 2012
    The ice cubes are fine and there is no water leaking into the bin. I read that I should check the drain to see if it is clogged.
  • howard thompson Jun 16, 2014
    99% of the time the drain is clogged.
2 Suggested Answers
  • 7 Answers
SOURCE: Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Posted on Aug 23, 2010
Water in the ice compartment with ice. How do I drain?
There should be a 3/4" fitting and 3/4" pvc pipe either on the back or on the bottom. Sounds like it's stopped up. Try blowing out the drain line first, but blow from the machine not back into it.
Aug 26, 2011 | Scotsman Ice Machine - 290lb...
Aug 02, 2010 | Scotsman DCE33PA1BC 15in Built-in...
I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Nov 05, 2009 | Scotsman DCE33PA1BC 15in Built-in...
A continuous grinding sound on my Scotsman DCE33A
I would suspect the water pump is making this noise. If it is, there is no repair, you must replace it.
Jul 01, 2009 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman icemachine m# DCE33A-1WB ice cubes are hollow
There is a cube size thermostat that energizes the timer. If it has been energizing early try a thicker setting on the cube size. If still gives problems ... your trouble was back in Feb I assume in cold weather.. If the machine is not in a room where the temp stays above 65'f this can also cause premature harvesting as you discribe also. Also if you are loosing water from the water curtian not sealing off it will cause the problem you discribe because the water is dripping off and out before it can freeze. Any futher questions please post. If this helps you understand your trouble please rate me as high as yuou can, thank you for using fixya
Feb 11, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Refrigerators Logo
272 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
