Harmony touch reboot continually
No way to to connect to myharmony.com, the remote is always rebooting. Is there a way to hard reset to factory setting on the device itself (the "off" button during 15 seconds doesn't work, it reboots again before 15s!)
    New Friend:
  • 4 Answers
Here is a confirmed solution - it helped with mine Harmony Touch:
- Press and hold the Off and Menu button for 30 seconds
- Log in to you Harmony account
- Connect the remote to PC and sync it.
Posted on Jun 06, 2013
SOURCE: screen keeps rebooting
This is probebly an issue with the battery being loose. You can do the following:
1. Fold up a pice of paper and put it against the battery then put the battery cover back on. The paper will ensure a snug fit.
2. Click "Downloads" in the sofware and select "Firmware". The remote's firmware will up updated.
3. Update the remote.
Hopwfully that will stop the remote from rebooting!
Posted on Mar 05, 2010
  • 76 Answers
SOURCE: Frozen LCD on Harmony 880 Remote
Ah, the 'blue screen of death'. Before you give up on this try one more thing -
Sometimes putting the remote in 'safe mode' and doing a firmware update will bring the screen back to life. Here's how:
Launch the Logitech Remote software on your computer and click on "Downloads" (on the top menu bar). Then, take the battery out of your remote and at the same time you connect the USB cable to your remote (it should be already connected on the computer end) press and hold down the Off button at the top of the remote. This will put the remote in "safe mode". Continue to hold down the Off button until you see the message "safe mode requested" on the remote's screen and the screen starts blinking. Now, since your screen is not behaving properly, you may or may not see this message, but after about 5 seconds you can release the Off button. Now, go back to your computer and click on "Firmware". If the software is able to communicate with the remote, an update to the remote's firmware should be executed. This has solved many a 'blue screen of death' problem. Good luck!
Posted on Mar 06, 2010
SOURCE: Harmony 550, TV comes on, then shuts off
Can you test it again, and look at the remote. Does the remote flash, indicating that another command is sent that is powering off the TV?
Posted on Mar 26, 2010
SOURCE: device freeze how to I reboot
Hey, try doing the following:
1. Remove the battery, press and hold the 'OFF' button, and re-insert the battery. The screen will display 'Safe Mode!', or the 'Activities' button will be lit.
2. Connect your remote to the computer.
3. Launch the Harmony Remote Software, and log in.
4. Click "Downloads" at the top and click "Firmware".
5. The remote will go through the firmware update.
6. Select "Yes", and click NEXT to update the remote.
That fixed my 550 a couple of times. Seems that a firmware update will cure most ailments.
Hope it helps.
Posted on Apr 07, 2010
budmrtn
  • 11361 Answers
SOURCE: Brand new 55" Samsung LED
Well, you may have problem inside the TV, to find out for sure is to use this remote with SAMSUNG TV in the store where you bought it from, if it works, then I would demand them to give you a new TV since it may be a LEMON set which I would not want to own if it breaks down already, if the remote does not work in the store then ask the store to give you a new one.
Please leave rating if it helps.
Posted on Jan 20, 2011
Deracam will not reset. How do I get it to reset?
If you want to reset your IP Camera to factory defaults, you can use the following 3 methods. After resetting the device you will lose all your settings except Client Settings.
Method 1:Hard reset/ By pressing the RESET button
Step 1- Keep the device powered on for at least 30 seconds to complete its normal startup.
Step 2- Find something like a pin to press the Reset button on the camera and hold it for 15 seconds to restore the settings to factory defaults.
Step 3- Afterwards release Reset button, and the camera will be restored to factory defaults after rebooting.
Note: Reboot process takes about 1 min, please be patient.
Method 2:By using Intelligent IP Installer
Step 1- Install the Intelligent IP Installer with the CD.
Step 2- Run the Intelligent IP Installer. Click Search to find your device.
Step 3- Select your Camera in UPnP device list, click Factory default on the right side.
Step 4- Type the username and password in the login page, the default username and password are both admin. Wait for the device to reboot.
If you changed the username and password before and forgot the username and password, you have to follow
Method 1, make a hard reset.
Method 3:By using Web-based Utility (management page)
Step 1- Open the web browser and type the IP address of the IP Camera into the address bar, press Enter. If you have changed the default port number is 80, Then type the IP address of the camera: new port number into the address bar of web browser.
Step 2- Type the username and password in the login page, the default username and password are both admin. Then click OK to connect to the device.
Step 3- Click SETTING -> BASIC -> Initialize on the left side, and then click Factory default to reset this IP Camera to the factory default settings.
Step 4- Keep waiting until the progress bar shows completion.
Feb 04, 2018 | Miscellaneous
Why does my nextbook keep asking me if I want to put it in safe mode?
The device went into safe mode because the app that you downloaded was not a safe application. The device does this so that the application cannot cause more problems to your device. Even though the app was downloaded from the app store it was not deemed safe by your device. Here are some tips that will help you to get your device out of safe mode: -Ensure that if you have a case on your device that you take it off being that the case may be holding the volume button causing you to boot into safe mode -Try turning the device off then back on to get out of safe mode -Power off your device, then reboot by holding the power button + volume up key, then in the boot menu select reboot device -This is sometimes caused by the users accidentally tapping safe mode when cutting the device on so simply restart your device Most users have success by simply restarting the device in order to be able to get out of safe mode. Do your best to restart or reboot your device before you have to perform a hard reset to get the app off of your device to no longer go into safe mode In order to hard reset -Power off device -Hold down volume up + power -Release at the boot menu -Use the volume keys to highlight factory reset -Press the power button to select factory reset -After this the device will begin to reset itself -After it resets itself use the volume keys to highlight reboot device -press the power button to have your device rebooted in its factory settings
Apr 20, 2016 | Nextbook Tablets & eReaders
I have a vizio va3203 made 2009. Hd eco. How do I reset it. To factory without remote
You have to enter its service mode to do a factory reset. There is no other way to do this without a remote control. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Nov 21, 2015 | Vizio Televison & Video
How do I get my nextbook tablet out of safe mode?
Nov 04, 2015 | Nextbook Tablets & eReaders
I have a 32" flatscreen somehow the remote is busted the keys on the tv itself is locked how do I reset. Please help?
You can't make a reset to this TV; without its remote control. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option.
To get more visit this site.
Feb 23, 2015 | Televison & Video
Does anyone know how to reboot/reset a BUSH idpvr802 freeview digital box without using remote
You can't set it to its factory setting [reboot]; without its remote control. There are two types of reset to. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 02, 2014 | Televison & Video
My tablet keeps rebooting itself and asks me for my info. WHY?
It might be installing updates. If it continues to reboot, do a hard reset, or a factory reset. You'll have to type your information in again, but it should stick after a reset. Also, make sure that you are saving your Wi-Fi network information (Such as setting it to automatically connect).
Aug 18, 2014 | Proscan 10.1-Inch Internet Tablet,...
Why is my linsay tab is stuck on the reboot screan
There might be problem with your firmware version of the device.
Do a hard reset of your device, hopefully it will be solved. Here is the instruction:
Suggested From: Samsung Galaxy S6500 Unlock Code Sim Network Pin
Performing a Factory Reset on Samsung Galaxy S6500:
1. Hold both the volume up key and the power key at a time to start the phone.
2. Command to Factory reset /wipe data>>>delete all user data>>>reboot system now
3. HARD RESET COMPLETE.
How to Hard (Master) Reset?
1. Select "Menu">>> "Settings."
2. Go to "Privacy">>>"Factory Data Reset".
3. "Format USB Storage" CONFIRM TO CLEAR DEVICE..
4. "Reset phone.">>>"Erase Everything" confirm to reset to factory settings.
Jun 22, 2014 | Samsung Galaxy S Ii S2 I9100 16gb Unlocked...
I am not receiving emails. Also, the device sometimes changes from sound on to sound off by itself.
If I may ask, have you power cycle (Reboot) your phone? Rebooting may help to resolve the problem.
If reboot didn't do anything please let me know.
Jul 26, 2011 | HTC Droid Incredible Cell Phone
Galaxy p1000 is frozen cant switch off nothing is happening
Hope this helps:
How to Hard Reset Samsung GT-P1000 Galaxy TAB:
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
Hard Reset Samsung GT-P1000 Galaxy TAB with keys With the Samsung Galaxy TAB turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Feb 05, 2011 | Samsung Galaxy Tab Tablet PC
Televison & Video Logo
801 people viewed this question
Top Televison & Video Experts
