Question about Caroma Home
The flush buttons have no resistance and do not flush
The toilet does not flush when depressing either of the dual buttons but the buttons depress with no resistance - how do I empty the toilet bowl
  • 659 Answers
SOURCE: Toilet won't shut off
Does it leak from the overflow? If so then the washer at the top of the Fluidmaster needs to be replaced. If it is not going over the overflow then you will need to replace the flapper on the flush valve.
Posted on Apr 11, 2009
SOURCE: Push Button - Have to Hold Down Button
I had the same problem. The fix cost me 50 cents (literally). I just placed a quarter on top of the Blue and White flush buttons (not sure of the technical terms) inside the tank and now it flushes properly. It seems that the 2 plastic poles the extend from the faux chrome buttons are just a bit too short.
Hope this helps
Posted on May 02, 2009
SOURCE: cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
Posted on May 08, 2009
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
  • 10 Answers
SOURCE: When i flush the toilet, the bowl doesn't fill
there is an ajustment on top of float assembly
to adjust level of water in tank
Posted on Nov 01, 2009
The dual flush cistern does not empty when the buttons are depressed. They have to be held down to clear the toilet bowl. How can I fix this?
cisterns never completely empty as the setting of the mechanism to close the valve is activated when it gets heavier than the water supporting it
try allowing more water into the cistern on a fill by adjusting the water level control
get a plumber in to clean out the sewerage pipes as there appears to be an obstruction in the line
Jun 13, 2015 | Home
How to remove a parisi nahm soft close toilet seat
there is 1 of two ways.
easy way is have a look where the seat mounts to the toilet and see if there is a cover that you can lift up and find a screw under it. there might be 2 pins on each side of the toilet seat hinge that you depress for you to remove the seat from the hinges to access the screws.
failing the above method the toilet has to be removed to access the screws / wingnuts from under neath. send closer picture of hinge on seat if you like.
Jul 12, 2014 | Toto Aquia II Dual Flush Toilet
Flapper valve closes too quickly
Fill the breather hole (1/8" hole) inside the flapper.This is designed to let air out so the flapper will sink. Now it floats longer letting in more water. 25%percent more in my case.
Apr 22, 2012 | Home
Cant get the lid off a push button cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to left out the second button, then release the first button and pry that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
Feb 01, 2011 | Duravit 0910100005 Happy D Toilet Cistern ...
Tilet want flush no pressure when depressing
Take off the top lid and look at the flush handle mechanism. You'll see a not that holds it onto the tank. Tighten the nut so it is snug. Don't overtighten it or you could crack the tank. Next inspect the chain that goes between the end of the flush handle rod and the flapper valve. It should lift the flapper all the the way up when you operate the handle.
Apr 11, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
Cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Oct 29, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
After depressing the flush lever the flapper closes to quickly
The flapper is designed to close quickly. It holds more water in the tank then it uses to flush. That way it is ready to flush again quickly.
If it is not removing all the contents then there may be an issue with venting or blockage in the pipe.
Oct 18, 2009 | American Standard Cadet 3 FloWise...
I hAVE A TECMA RV TOILET THAT IS NOT FLUSHING. WHEN YOU PRESS THE PAD FOR WATER SAVER FLUSH, THE WATER DOES NOT GO OUT AND MORE WATER ENTERS THE TOILET. IT HAS OVERFLOWED SEVERAL TIMES. WHEN YOU DEPRESS...
Your macerator has likely failed, unfortunately. There is a fellow Mobile RV tech (RV Medic) in Springfield, I am pretty sure he services Branson as well. Perhaps they will be able to get you fixed up.
Aug 16, 2009 | Thetford Porta Potti
Hope this helps
Feb 18, 2009 | Toto Aquia II Dual Flush Toilet
Home Logo
198 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
